It's 2023! Are there ANY decent canbus ready H7 & H11 bulbs yet?
Forgive me. I'm making this request here because I've researched LED headlamp/foglamp options until I'm blue in the face. I can't seem to find the best recommendation.
Any ideas guys? Are there ANY good quality H7 LED's that will work with the w211 factory halogen projector headlamp housing? Or how about an H7 LED that will work with an ebay factory halogen style projector headlamp knockoff?
And the H11 foglamp too? Any good H11 LED's ?
It's 2023, one might think there would be some decent LED plug and play options for our W211's.
Thanks!
low beam: Beam tech H7 led $32 eBay
Fog light: Mostplus H11 $29 eBay
just plug & play, No error code on w211,.
Do you have the ebay links for the actual bulbs you are describing? Just so I make sure I get the right ones!
Thanks @taylor210
I would think that the triangle shaped head LED bulb would work better for our projector style headlights than the silver rounded head.
How about the H11's? Do they fit ok in the foglight housing?
Details please, thanks!
the boxes showing a part numbers attached but no need to worry. all you looking for is H7 Beamtech for low beam and H11 Mostplus for the fog light. The color temperature and Luminous Flux are pretty much similar.
The H7 led fits perfect into the headlight housing and black dust cap also fits like a glove. Enough space between the dust cap and wires. They said that make a 2 small holes on the dust caps for cooling the fan but I haven’t done it but no issue so far…
The black triangle head is one that I have in the car. The silver rounded, newer version came out not long ago so I do not know anything about it.
For the H11 led fogs, fits perfect as well and fog light housing on w211 did not come with dust cap from the factory. I don’t know why but my H1 led on my w210 has a dust cap in the fog lights housing tho…
I’ve bought over 5 different other brand of H7, H11 and H1 led lights prior to these lights for w210 and w211 (Lasfit, Auxito, zentec, Extreme…). They had all the good reviews but None of them work on these cars. Most of them had an error code and only lasted a few months or less. I’ve spent a lot of money and times on this…. Over all, I’m good with the Beamtech and Mostplus brand, not even a single issue so far…
I bought it from 2 other sellers from eBay mentioned above so they should have these items for you. Amazon also has these but it cost way more than eBay. Let me know if you’re having a problem finding the right items.
H11 fog
H11 fog
H7 low
H7 low
As you can see my 09 did not equipped with dust caps
Black triangle head type h7 for low beam
@taylor210 . Hey I got new headlamps and just tried to install the beamtech H7's you recommended. I see they fit in the hole, but how did you mount them? How did you make them fit? The original stainless steel clip does not fit over the beamtech h7's. How did you do this? Did you cut the clip? Or did you buy a new clip?
