No start, starter fuse 59 blows whenever I try. Help!?
However, if you removed battery cable from the starter, you have a defective starter solenoid.
What engine and year, how many miles/kilometers?
Ok so I did remove the battery cable directly from the starter (I removed both of the cables) and it still blew the fuse. So I'd love to have it just be the solenoid but I can't find sense in your diagnosis, how is the solenoid blowing a fuse when it's not even connected? Especially with how I botched the bcm pins and all the sparadic codes?
and the pin I bent in the bcm is probably what was throwing all the codes but had nothing to do with my starter problem. I guess it was just a coincidence that it all happened at once and it just overwhelmed me. Lesson learned, always stick with the basics and don't over complicate things like I did.
Thank you for the help!
Why? That wire should have never been rubbing against anything, even less the engine. Taping the wire has restored the wire protection, but it may rub again, and the short may be back. Perhaps worth looking for a broken snap, tie wrap, strap alomg its path and try to fix it so the wire is in its correct path again.
If you take a DVM
1 - Remove the offending fuse, and with the ignition ON, you should be able to measure @12V on one of the fuse box pin/latch for 59, and nothing on the other.
2 - Once you have identified the non-voltage side, you can put your DVM in continuity mode (with the annoying and helpful beep),
3 - Connect one of the wire to the non-voltage leg and the other to a good ground on the body/engine and it should beep, correct? it is shorted.
4 - With patience and beep ON, you can start moving, disconnecting wire as you move from the fuse box to the starter
5 - When the BEEP goes OFF, Stop and review what you just did. The offender is nearby.
Did you check the starter relay (L) in the diagram is good (https://fuse-box.info/mercedes-benz/...uses-and-relay
If you take a DVM
