Rear differential fluid change
What diff fluid is everyone using? Redline worked well on my japanese cars but assuming not so much with Mercedes.
https://www.pelicanparts.com/techart...uid_Change.htm
Another detailed set of instructions (no photos though)
https://forums.mercedesclub.org.uk/i...-change.98378/
and, of course, the commercial video
Fluid - spend your $ on whatever makes you happy or marketing your believe in. Official spec is 235.7 - https://operatingfluids.mercedes-benz.com/sheet/235.7
Change interval - everyone will give different answers. General guidelines that will not start a flame war. If you live in a place with high humidity or wide temperature ranges especially sub-zero F - change it more often to remove water condensation.
https://www.amsoil.com/p/severe-gear...EA/&zo=7236674
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
On my CLS55, I swapped them out straight away when I did this service.
You can probably use this as a guide as well:
https://www.youtube.com/watch?v=2IP9E8iVcLE
Can you please confirm if I have the correct part number for the plug screws "A0009977932" (assuming it's the same for fill/plug)?
My car is a 2015 CLS400 (Base, Non 4Matic).
Thank you
