Transmission dipstick missing??? '07 E-350
So I actually did my research before posting this on here on this site and on other sites which all say that back by the oil dipstick which is in the pictures below (yellow cap) there is a Red Cap with a lock on it for the transmission. I am actually having issues when I get past 5000 RPM and higher when I take my foot off the gas pedal the car doesn't slow down RPMs as quick as it should it stays very high like 5,000 or more and eventually it clicks in and then starts going back down as the car slows down so obviously it's sticking in some of the higher gears when I'm not even giving it any gas from the pedal aka the pedal is just not being touched and it doesn't lower the RPMs as quick as it should. I actually found a cool like 1 oz transmission treatment that's supposed to fix this issue in European cars and German cars and he just pour it down the transmission dipstick. Obviously it's a temporary fix until I can spend a bunch of money to go to the dealership or somewhere and have the transmission flushed and replaced in a new filter put on. I don't have that money right now. My question is after reading everywhere that 2002 is it until 2009 these vehicles have that dipstick next to the oil dipstick how come my car doesn't have that? Yeah I've included pictures so you can see both sides in back of the engine there is just no dipstick only the oil dipstick so where can I access a place to add this transmission fix fluid since I can't find the actual dipstick and why does my car not have one when all cars made between 2002 and 2009 are supposed to have one right or am I just reading everything wrong on these forums and others?
From my understanding, if you have the RWD car, which used a newer 7 speed transmission, there was no tranny dip stick!!. If you have a 4Matic car, which used an older 5 speed tranny, there might be a tranny dip stick (I dont have this car so dont know). My older W202 used this same 5 speed tranny and had a dip stick like you described.
Received 1,506 Likes
If it's the 5 speed, the connector wicks up transmission fluid causing those weird shifts. Replace the connector and don't add any miracle in a bottle to the car. Probably making it worse by contaminating the fluid. You can use Shell ATF 134 from a Shell distributor and it's about $80 for a case of 12 quarts. Lots of places like FCPEuro and Rockauto sell the transmission filter.
https://www.fcpeuro.com/products/mer...tor-2035400053
Thanks - and so if 5 speed this should fix it I can forego doing a tranny flush - even tho is 17 yrs I thought you should as preventative mtce change filter and add new fluid every 100k miles or something? I am 155k miles
Here is the vin how can I tell what engine I have? (5 or 7 speed transmission right?)
Also I hope your balance shaft is ok, you're in range for the problem but if you don't have any engine codes, who knows when/if it will go. Many threads on here about the balance shaft.
https://www.lastvin.com/vin/vJ8m3d3abO52X7e0W
You have the 7 speed transmission so no connector. You're supposed to change the fluid every 39k miles though, not every 100k so it's probably long overdue. Might fix it after changing the fluid, otherwise it's probably the conductor plate. You can also try the transmission reset procedure.
SPONSOR
11 E550, 16 AMG GTS, 13 S550
stop stop stop
don't just dump random stuff in the transmission.
you can do the transmission service as EASILY as an oil change. VAICO filter kit on RockAuto.com
https://www.rockauto.com/en/moreinfo...=8600&jsn=1412
follow this link to buy Amsoil stuff for your car. You'll want 7 liters of the OE ATF for very little money, which is cheaper than Pentosin/Liquimoly. Engine oil if you haven't done it yet.
https://alphaeuropean.myamsoil.com/
I just need the car on jackstands or at an oil change place and you can borrow their time. Drain, remove the transmission pan, replace the gasket, clean the magnets. You can pay anybody for this.
Close up with new bolts, gasket. Fill it through the same port until it drains, run it til its hot, shift through the gears one at a time for 3 seconds. There are more complicated detailed ways to do each step, and it won't make a difference I've been doing this daily. Fill it 2 more times while it's running a half liter at a time to "rinse" the old transmission til you use the 2 last liters.
ATF Fill tool and Fill Pump
Total cost of parts should be less than an oil change. Make sure you get the Mann or Hengst oil filter.
Dealer wants $800 for a transmission oil change, you just need to bring a box of stuff to a Mercedes specialist and show him this forum post. If you want to support the forum, that link contributes towards my personal business which supports the forum.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Service Manager/Owner
Amsoil Independent Dealer #7236674
nd-photo.nl (11-15-2023)
stop stop stop
https://www.amazon.com/Slippery-Pete...853CNLYZ/?th=1
https://www.amazon.com/YHXGLJDKA-Transmission-Replacement-Mercedes-Automatic/dp/B0BDMM4L6Q/
Thanks - I am not good at under-the-car stuff - I will find a Mercedes mechanic who can charge "labor only" if I bring all the parts! Once I get ready to buy everything I will use your links :-) Yes, Mercedes quoted me $750! Yeowch! That is why was going to try this supplement but alas, no dipstick could not use it if I tried lol. Your way sounds way better glad it is semi-easy to do.
https://www.shell.us/business-custom...r-locator.html
https://operatingfluids.mercedes-benz.com/sheet/236.14
SPONSOR
__________________
tell your girlfriend that you would like a Service Jack and a couple of jack stands from Harbor Freight for Christmas 🤶
SPONSOR
...ask me how I started my business lol, it was on jacks and stands, sometimes 3-4 at once
__________________
