E-Class (W211) 2003-2009
Rear door leak
Old Mar 9, 2024 | 07:50 AM
Moanes's Avatar
Rear door leak
Hey everyone ,
I have e320 2005, recently when it rains I noticed a few drops on the sill of the door , doesn't get to the fabric inside , also some drops on the lower part of the door where it usually sits on the sill.
I posted some pictures,, anyone can help.
I replaced recently the pillar and outside garnish(also on pics).
Notice:it is dry in the pictures .
Old Mar 9, 2024 | 03:01 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Drain plugs could be clogged, and the door weather stripping could be dirty. Endure the lining is seeded in its holes. Remove the stripping and clean. Check drain in the cowl (Windshield). I hope this helps.
R,
2Merks
Old Mar 9, 2024 | 03:23 PM
Moanes's Avatar
R,
2Merks
Thanks for the reply..
You mean the cowl in front?
And where are the door drains located are under the weather
stripping ?
I Don't really know how the door drains
Old Mar 9, 2024 | 04:04 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
stripping ?
Yes, cowl in front..You have drains on both sides of cowls. As for the door remove rubber weatherstriping. They have "lil nibs" that strips goes in, but ensure they are seeded. Not necessarily, but if stripping arent in perspective holes, water "could" ease in. Hope this helps
R,
2Merks
Old Mar 9, 2024 | 04:17 PM
Moanes's Avatar
R,
2Merks
Thanks a lot
Old Mar 9, 2024 | 05:12 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Thanks a lot
No worries..Trying to assist! GL
R,
2Merks
Old Mar 20, 2024 | 01:12 PM
Moanes's Avatar
R,
2Merks
So today it was raining , I saw that that also front door has a drop of water on the aluminum step( this one has
new weatherstrip) so I assume that the problem is not the weatherstrip.
I removed the rear door panel , and I think the interior seal is not stick properly by the Butyl( I posted a picture ) , I think some drops entering from the outside space of the door through this seal maybe .. I will try to seal properly .
Let me know if you have another idea please .
Old Mar 20, 2024 | 10:45 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
...Gonna have to dig a little deeper.. I'll check back.
R,
2Merks
Old Mar 23, 2024 | 09:55 AM
2MERKS's Avatar
'99 CLK/05 E500 WAG
I was thinking it could be the window seal.
R
2Merks
