E-Class (W211) 2003-2009
2009 W211 M272 engine intermittent misfire
Old Nov 4, 2024 | 02:11 AM
Hamza yagan's Avatar
W211
Hi to all ,
I have an intermittent misfire problem mainly on cylinder 2 and 5 , when it happens the engine will vibrate like crazy , if I leave the car off for long hours it acts normally again for days but the DTCs come back immediately.
new spark plugs installed , O2 sensor number 1 left replaced and it cleared a short circuit DTC but the car is still working intermittently . Attached are the DTCs .
I suspect a bad ECU since i have an < ECU internal error > code .
kindly share your thoughts .
I can't keep troubleshooting without trusting that my ECU is good first .
so I am thinking of replacing it .
Old Nov 4, 2024 | 03:33 PM
W211
Originally Posted by Plutoe
is this a stoled or water wrecked or tuned car???
It's my dear car that i have been using for 10 years .
Old Nov 4, 2024 | 04:54 PM
trigital's Avatar
W213 All-terrain
If no little mouse scratch the wiring harness, is it a good idea to make a software backup from your ECU and to wait for a good deal on ebay till you repeat the diag with a proper tool.
Old Nov 4, 2024 | 06:09 PM
W211
Yeah could be a wiring issue , ill get the ECU replaced , if its not fixed I'll start the wiring check on the components listed on the DTCs .
Old Nov 4, 2024 | 09:35 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You did noticed most of your codes are HISTORIC is. not current fault.
How long foes it take to come back when you clear ECU Fault?
Have you inspected the ECU plugs for oil swamp??
Have you tried to reboot whole chassis by disconnecting all batteries for 15mn ?
Then scan data for live fuel pressure value near 60Psi.
Old Nov 4, 2024 | 10:13 PM
W211
Yeah I noticed once I clear the codes they come back on the same day .
Ecu plugs inspected
I removed only the negative battery terminal for more than an hour.
fuel pressure not inspected but why whould fuel pressure set a code for a faulty ECM ?
Old Nov 4, 2024 | 11:36 PM
Ecu plugs inspected
.... why check fuel?
because you have multiple misfiring faults.
every fault coming back including "historic" that means unstable transient conditions.
Old Nov 5, 2024 | 01:20 AM
W211
yeah that would be a priority when I am troubleshooting a typical missfire issue , but when the ECU that gives this fault says that the ECU is internally defective that code would be my priority to fix , then I can rely on the other DTCs , however I will check the fuel pressure just for the sake of it , i tried to find the data in the scanner b4 but could not find it so ill just use a pressure gauge.
Old Nov 20, 2024 | 05:36 AM
W211
Solved
Hi all ,
Finally solved the issue, I had multiple intermittent faults thats why it took a while .
1) Bad ECU
2) fuel injector 5 getts stuck intermittently
3) bad lambda sensor
4) vaccum leak from a hose
All fixed all okay now .
If I had a scan tool that could clone a used ECU i would have solved it earlier.
BTW anyone knows what is the cheapest Autel model that is capable of cloning a mercedes ECU offline ?
Old Nov 20, 2024 | 02:58 PM
Bad ECU... heat damages
This is very good news
-- You can look at "Launch MB Creader Elite": it does cloning at $150 price point.
-- Try changing engine oil at 5kMi to reduce high engine heat.
Old Nov 20, 2024 | 03:01 PM
W211
You an look at "Launch MB Creader Elite": it does cloning at $150 price point.
Thank you very much 👍
