E-Class (W211) 2003-2009
Old 06-10-2015, 12:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brake Guides
Print Wikipost
W211 DIY Brake Job
Old 02-08-2014, 01:43 AM
  #251
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
^ once you disconnect the SBC, youre good to go. I havent done any major DIY til i replaced the rotors and pads on mine (i think it can be called a major DIY) but id give it a 3 out of 10. I was hesitant too but when i started, i cant believe it was that easy. So long as you have the right tools, you can do it with your eyes closed. But i wouldnt recommend it. 😀
Old 02-08-2014, 01:56 AM
  #252
Last2Die's Avatar
2003 E320
so one you take off the caliper I assume in 2 parts you wont have brake fluid all over the place?
and the rears are all bolts ..? and the rotor is held on with a set screw in the front..?
The caliper thing makes me nervous, I have all the tools just dont want to get error lights or have my wife kill me !!! haha
does anyone have the rest of the pictures..?
thanks,
Tony
Old 02-08-2014, 10:44 AM
  #253
PeterLech's Avatar
2006 E350
thanks,
Tony
Floating calipers refers to the design, the fluid does not come out when you take them off the disk assembly. Be sure to support the calipers and not let them hang by the fluid hose - I use a bent coat hangar to hold them up out of the way.
BTW, Bosch "QuietCast" pads have remained squeak free after several months, are slightly less dusty than the stock pads.
Old 02-08-2014, 11:52 AM
  #254
Last2Die's Avatar
2003 E320
Ok thanks peter that helps !! So I understand let me just put out what I will be doing
1 disconnect the sbc via the connector under the hood, take off the brake top on the master
2 no need to close the hood or lock the car just don't open the door or push the brake pedal till I'm done.
3. From here just your normal brake job except the passenger side sensor for the rears and the use it torx bolts?
4. So I think 4 bolts and I can have the caliper off
5 the set screw on the front will make it so I can remove the caliper.
I think I got it. I'm only replacing the pads as the rotors are fine.
The final step is reconnecting the sbc closing the brake fluid resivior pushing in the brake pedal starting the car remove foot and all is good right ...?
Tony
Old 02-08-2014, 03:49 PM
  #255
jandmtv's Avatar
2010 GL450
Man I'm glad they did away with the sbc brakes. Seems like an awful lot of hoops to jump through for just a DIY brake job.
Old 02-08-2014, 05:38 PM
  #256
Last2Die's Avatar
2003 E320
it is a lot of hoops !!
I think the only thing i need assistance with is the right way to finish the job. Once the new pads and rotors are on the rear tires are on i go back to the engine compartment where the hood is still up and I reconnect the SBC. After I connect the SBC close the hood open the door.... do I...
1. Step on the brake and start the car with the brake pressed to the floor..
or
2. pump the brakes before starting, start the car after pumping the brakes 3 times..
or
3. start the car as normal after car is running pump the brakes or dont pump the brakes.
SO any advise will be really helpful as far as finishing the job and doing things the right way and not getting any errors or red lights.
Thank you
Tony
Old 02-09-2014, 01:45 PM
  #257
PeterLech's Avatar
2006 E350
or
or
Thank you
Tony
When I reconnected the SBC plug and then put either opened the door or put the key in the ignition (I forget), you could hear the pump repressurizing the system. I do not recall doing anything special after that, and everything worked A-OK.
Old 02-09-2014, 04:13 PM
  #258
beejAMG's Avatar
once you're done replacing everything, reconnect the SBC, pump the brake pedal a few times, release the brake pedal, start you car then pump the brake pedal again. you'll hear the hydraulics working and you're good to go.
Old 02-09-2014, 05:48 PM
  #259
Last2Die's Avatar
2003 E320
sweet thanks I will be replacing the pads next weekend !!! I'll let you know how it goes !!
Tony
Old 02-09-2014, 06:30 PM
  #260
beejAMG's Avatar
Tony
goodluck! im sure youll be fine.
Old 02-09-2014, 07:56 PM
  #261
vettdvr's Avatar
03 E500 and Corvette
IF you hold the pedal when you energize the system it will seat the pads and possibly avoid a brake warning light. Pumping the electric pedal will have no effect.
Old 02-09-2014, 09:31 PM
  #262
beejAMG's Avatar
^ listen to him...vettdvr is one of the guys who helped me with all the info i needed before I went ahead with the DIY.
Old 02-09-2014, 11:40 PM
  #263
jandmtv's Avatar
2010 GL450
Tony
How will you let us know how it goes if your calipers take your fingers off?
Lol. J/K
Old 02-11-2014, 03:35 PM
  #264
Last2Die's Avatar
2003 E320
Lol. J/K
Funny LOL, well I may not be doing th brake job cant get the dam lugnuts off !! My impact gun goes up to 230lb of torque and I cant budge the rear lugnuts !! They were just taken off last week for service from my mechanic now I cant budge the darn things !! Bummer !
Tony
Old 02-11-2014, 03:52 PM
  #265
vettdvr's Avatar
I was shown how to remove them with the tire tool. The mechanic put the tire tool on then jumped and pushed with all his weight on it with one foot. I guess that would be in the service manual.
Old 02-11-2014, 05:18 PM
  #266
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Tony
Let me guess, that wheel was already jacked off the ground?
Old 02-11-2014, 05:23 PM
  #267
Last2Die's Avatar
2003 E320
Nope, not my first go around LOL I think my impact gun is crap honestly. Time to put the tire tool in like vettdvr said and jump !!!
Tony
Old 02-11-2014, 05:31 PM
  #268
beejAMG's Avatar
+1 on the tire wrench and standing/jumping on it. do it gently but. dont let a stubborn lugnut get in the way of a good DIY.
Old 02-11-2014, 05:43 PM
  #269
N_Jay's Avatar
Tony
Get a proper breaker bar. (and good 6 point socket)
Or get a cross wrench and then you can put the far end on a jack stand so you are not forcing the wrench off the bolt head.
+2
Old 02-11-2014, 05:59 PM
  #270
Last2Die's Avatar
2003 E320
I got em loose !! Put on the tire tool and applied my weight gently no problem !!! Thanks guys !! Looks good just going to put on the new pads this weekend !!!
Tony
Old 02-11-2014, 07:54 PM
  #271
Last2Die's Avatar
2003 E320
If I do get an error what steps should I take to clear them ? I do own a obdII reader than can clear the error code anything more than that I don't know.
Thanks,
Tony
Old 02-12-2014, 01:50 AM
  #272
jandmtv's Avatar
2010 GL450
Obd readers only clear cl (check engine) light. Not brake.
Old 02-12-2014, 02:42 AM
  #273
Last2Die's Avatar
2003 E320
Ok what would be your advice if I get a brake error light ?
Tony
Old 02-12-2014, 06:27 AM
  #274
vettdvr's Avatar
IF you get the brake light check the sensor plugs.
Just disconnect the SBC leave the key out of range.
When compressing the caliper piston back in crack open the bleed screw so the old fluid will not be forced back into the brake system and don't let air get in. Just crack open compress and with pressure still on the piston close the bleeder.
After completion top off with MB approved SBC fluid.
Old 02-12-2014, 12:08 PM
  #275
Last2Die's Avatar
2003 E320
Ok so I understand this, once I finish the job and the car is back on the ground I will plug in the sbc connector under the hood. Than with the keys in my hand I will open the door press the brake pedal and insert the key I will wait for the pressure to build and the pump to stop before starting. Once the pump stops start and hope for no error lights.
Tony
Quick Reply: W211 DIY Brake Job
