2008 E550 Right Rear Suspension Collapsed - Help?!?!
I've had my 2008 W211 E550 for 2 years and loved it until about 6 months ago. Since then - it's costs in repairs has been over $1,000 per month. Yuck. Starter - battery - engine / trans mounts - AC compressor - alternator and now the left rear (driver side) air suspension is collapsed.
I had this happen on the right side over a year ago and a local indy Benz shop fixed - cost about $1,500. Hoping to avoid as big a bill this go-around.
I've got a local mobile mechanic who has worked on the car before (eng.+trans mounts and AC) but I need to figure out what parts to get.
Issue is intermittent. The car holds air sometimes, it can go overnight and be fine and then randomly you come out from going somewhere and its collapsed. Always pumps back up ok so far. I've been sitting in it when just shut down and you can hear the air running out immediately and then sometimes it holds air overnight fine.
Does this require the entire air strut to be replaced? Can it be repaired by replacing just the air bellows part at the top of the strut? Are there rebuilt options that may save some $$$?
Any suggestions and advice is greatly appreciated!!!
Terry
First - Thank You for the reply!
So the clearly audible air leaking out hissing sounds would indicate the Air Spring is the culprit and that only replacing that should suffice? I do see Air Shocks for the rear but I would tend to agree that the audible hissing would seem far less likely from the shock than the spring bag. Replacing just the bag would also be much cheaper.
Any idea on how difficult this is to do or how long it may take? I've always been a DIY'er but due to my home sinking I am without tools and such so have to hire the job out. Working on newish modern cars is not my strong point. I can tune the MFI in a 50+ year old 911 but Benz air suspension seems a bit scary.
Terry
But I just remembered that Airmatic is different, there's an additional air chamber by the bag, and hose between them. I didn't hear any air hissing or air escaping, rear just slowly sank, so that hissing would indicate some other issue than a bag.
You should get your car on a 4-post lift, so you can go safely underneath and see is the leak actual bag or some related component.
Check the post #3 https://mbworld.org/forums/e-class-w...ight-left.html that shows the components.
I went out this morning after the car sat for over 36 hours and it had not deflated. This is not the first time that it failed to deflate after sitting so whatever the problem is it is intermittent.
Then when I sat down in the drivers seat the car immediately began to leak air from the right rear and deflate. The car was not running, no key in the ignition yet. But clear hissing sound and in 30-45 seconds it was fully deflated on the right rear. The left rear does not deflate in the same way - when the left drivers side is fully collapsed the right passenger side is only partially down - just a little.
Not sure what if anything this indicates...
I put the suspension into Sport Mode 1 and now it does not happen. Very strange. It has been 3 days and it has no collapsed again even after sitting for over 24 hours.
Any ideas on why this may be???
It is giving me a temporary "Malfunction" notice on the dash when I tell it to go to sport mode or lift now but it does look ok and rides fine. I am going to research how to calibrate it as I think that will solve the malfunction notice.
So I ordered a pair of Arnott air springs. Install is mostly done - BUT... with the air spring new, fully deflated and everything bolted back together the suspension is low enough due to gravity and such that the top of the deflated air spring does not make contact with the car chassis where the spring is supposed to center on the small plastic fitting. It's off by an inch or more. If I lower the car onto the wheels and then connect the battery and let the air suspension begin to inflate there is ZERO chance that the fitting will line up with hole in the top of the air spring for the fitting???
None of the instructions I have read anywhere say anything at all about inflating the air spring while the car is still off its wheel on jack stands. But that is the only way I can see that this could be done???
My plan is to place a jack under the suspension and raise it up until the air spring can be positioned with the top fitting aligned into the hole in the air spring and then reconnect the battery and put in the ignition key so it will begin to inflate... and hope for the best while prepared to remove a battery terminal quick if something goes wrong.
It's scary that none of the instructions or videos mention this issue at all???
Terry
Well, I didn't have the Star nor didn't know the correct method. When it was time to position the bag to the stud on the sub-frame, I placed 4x4 under the suspension control arms, and gradually lowered my car (as it was jacked up from the rear diff), making sure that stud goes to the hole. When it was said and done, I started the engine and watched as the bags inflated.
A horrid pain as it's very close to the fuel tank.
