E-Class (W211) 2003-2009
Squeaky wiggle sounds like owls coming from front right corner
Old Mar 21, 2026 | 11:20 PM
Slave IV's Avatar
2008 W211 E350 4MATIC, 1985 W123 300D Turbo, 2002 C5 Allroad, 2002 B5 S4, 2008 MkV R32
Anyone experience this and know what the cause is? Only happens when moving and the sound starts as soon as I start to move, almost like it anticipates I’m going to move and is ready to whine the moment the wheel releases from brakes. Usually more prevalent or maybe just more noticeable at low speeds. I noticed the sound went away for a short while after I changed wheels and I was hoping it was the cracked wheel I had that was making the noise but now the sound is back as much or more than before. The cv boots look intact and I don’t see anything else that is clearly loose or damaged. Thanks for any tips that lead to solving this annoyance.
Old Mar 22, 2026 | 04:05 PM
SAVZ's Avatar
2010 GLK350 4matic
Can you get a sound clip uploaded?
Old Mar 23, 2026 | 06:14 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Who?
Old Mar 23, 2026 | 02:23 PM
Slave IV's Avatar
Hope this gives the idea
File Type: mp3
Old Mar 25, 2026 | 05:29 PM
Slave IV's Avatar
Is that sound clip I posted clear enough to get any feedback from anyone or should I try another. I realize it might be hard to distinguish from background noise.
Old Mar 25, 2026 | 08:18 PM
F1Fan's Avatar
Most likely a suspension or possibly a motor mount issue. There is also the stabilizer bar bushing that can cause this sound. If you've replaced basically every component of the front suspension and still have this noise, check if the bushing is torn on the stabilizer bar.
Old Mar 25, 2026 | 10:23 PM
Slave IV's Avatar
Ok thanks. I’ll take a look at the suspension components. I have not changed anything and not sure if the previous owner did. Only had the car less than a year. If it’s just a bushing, are those typically replaceable or whole component needs to be replaced?
Old Mar 25, 2026 | 11:09 PM
SAVZ's Avatar
2010 GLK350 4matic
Did the noise disappear in cold weather?? My creaking suspension noise ( control arms) were almost silent in freezing temps and then made a sudden return when it warmed up. After replacing all
4 front arms it’s nice and quiet again. I could replicate the noise when I had someone bounce the car up and down from the front and I placed my stethoscope on the CA bushings, the upper control arm bushing were also tearing, the lower control arms bushings were good but the ball joints were very loose.
Old Mar 25, 2026 | 11:57 PM
Slave IV's Avatar
That’s a possibility as it did go away when I changed wheels but that was a while ago when it was cold and could have been a coincidence. Ow that it’s getting hotter and hotter, I notice it getting worse.
Old Mar 26, 2026 | 10:46 PM
F1Fan's Avatar
Could also be the lower ball joint. Those are a common wear item.
While the W211s have a fantastic ride, I feel the suspensions (especially the front) are not durable. Lots of things wear out quickly. A 2008 is most certainly overdue for a suspension overhaul; meaning replacing basically everything. If you are handy with tools, it's actually not that hard to do. Working on the W211 is very easy. Many articles are youtube videos are available. Also parts are not that expensive. I would suggest sticking with OEM suppliers. FCP Euro has a fanstastic lifetime warranty that comes in real handy when the parts wear out.
Old Mar 27, 2026 | 01:49 PM
Slave IV's Avatar
Appreciate the encouragement. I don't have a lift so not sure if I can handle the job with the stock jack and stands but I'll take a look. Most complicated suspension work I've done myself was swapping a rear anti sway bar on my S4. But, I agree Benz's have been easier overall to work on and I was already thinking if it's something I could and want to tackle myself. I can ask the PO about it too and see if he remembers if it's been done but I don't remember seeing it in the paperwork I got.
Old Mar 27, 2026 | 08:33 PM
timmy0tool's Avatar
2008 S211 4MATIC
i do believe W211s suspension are easy to work on, but the OP (and i) have a 4matic, and i find the front to be so much more complicated due to the axles! the lower arm has 2 inner bushings as it's an a-arm vs just 1 on a RWD car.
i recently lowered my 4matic and i have not heard anything similar to what you are experiencing. could it be the brake pads?
Old Mar 28, 2026 | 12:24 AM
Slave IV's Avatar
Yeah, I watched a video and although it didn’t look too bad, there are a lot of steps and some tools needed that I don’t have. If a 4Matic is going to be more complicated, I might just have to pass on trying it myself because I can already tell it will take me all day or more, even with the right tools and I still might mess something up. If I do all that, I’ll need an alignment anyways and if I’m already paying for that, I might have them do it all and get it dialed in.
If it’s a brake pad, that’s a whole different situation and I have been planning a full service when that time comes, some quality rotors, pads, ss lines and fluid flush. But I’ve never heard brake pads make a noise like that before. It’s usually a higher pitch squeal and only when brakes are applied and should definitely be affected either way if I brake. This sound seems independent from brake use but I’ll pay closer attention there too.
Whatever it is, it doesn’t seem to affect performance as I took the car on a canyon run road trip for the first time and suspension and brakes were all feeling solid. But it is hard to say if I don’t have perspective to feel what it should be if there is a bigger issue.
Old Mar 31, 2026 | 09:16 AM
filgarg2's Avatar
W211 E320 4Matic
Probably a lower ball joint or a bushing from the lower control arm. Classic issue on all the W211's.
Old Mar 31, 2026 | 11:55 AM
Slave IV's Avatar
thanks! So you’re saying that sound is a typical tell for the issue? Makes sense.
