Question for those who got Terk SAT antenna
I had mine done recently from Caliber Motors in Anaheim, California. They used the small Terk antenna. My wife actually got this for me for Christmas and surprised me with the completed car. My point to this, is that she did not ask for anything special, just said she wanted the sat install for my 04 E320. I would call Caliber and enquire for more info.
Jeff
Both the SIR-MINI and the American International SIR1-SAF (which I just ordered from Crutchfield) are pretty darn small antennas, and are actually designed for the correct frequency bands.
I just received the Sirius OEM hardware, but don't have the car yet. I think it just cleared customs, which gave me time to swap antennas and add the SIR-SP splitter to the box before I give it to the installer.
Enjoy the music. Its such a break from AM & FM you'll never go there again!
antenna, any problems caused by the window tint, etc?.... I will use your photo to show the dealer in LA when I get my Sirius installed (car is April delivery).
installed on rear shelf, at bottom of inside rear glass.
So yesterday, the satellite kit was installed, but to my dismay, they installed the antenna on the trunk! Which I guess is the “normal” location. I was disappointed because I really don’t like the look of the antenna on the trunk. So I talked with the service rep. and he initially offered to paint the black antenna to match the car color. But I wasn’t happy with that and mentioned to him that when I bought the kit, I was told the antenna was installed inside the car. After talking with the parts department, they said that it “can” be installed there, but by default it’s installed on the trunk. So I thought I was screwed since I didn’t mention the install location when I bought the car in. I asked if they could move the antenna and was honestly surprised when they agreed to move it to the inside of the car, fix the hole in the trunk and give me a rental during the two to three days it would take… all at no charge to me… in fact they were apologetic for the screw up.
But to get to my point… the tech was initially thinking of moving the antenna to the inside, but obviously the stock antenna is too big to fit in the space behind rear shades. They don’t seem to be aware of the Terk antenna, but said they were going to contact Mercedes to figure out what antenna they need. They said I was their first customer to request an inside install. So does anyone have any additional info on the Terk? Part numbers etc. Is a special wiring harness needed? Just want to have this info in case they’re not able to figure it out.
The receiver has blue and white FAKRA connectors, which are intended to either connect directly to an antenna with two connectors (terrestrial/satellite), or a device called an automatic level control (ALC). I have had no luck finding an ALC yet, though I understand they're cheap little devices. The purpose of the ALC is to prevent interference from XM's high powered terrestrial transmitters, amongst other things.
The factory Sirius antenna only has two wires, so you'll need the Terk SIR-SP splitter (which is available everywhere) if you want to use a one-wire antenna, as most are these days.
The SIR-SP has curry and white colored connectors and doesn't exactly mate with the blue and white connectors on the factory receiver. You have a couple of choices as to how to fix this. The proper one is to get an ALC, which would have blue and white connectors on one side, and curry and white on the other, which would then plug into your splitter.
If you survey the Sirius message boards, you'll find a bunch of people who have had their ALCs fail, and who dispensed with them entirely. To do this, you have to shave a little rib off of the factory radio's blue connector and plug the curry connector from the SIR-SP right onto it. I did this, and it works great so far, but I'm still going to try to find an ALC to do it right.
I really like the little American International antenna I referenced earlier in this thread. I think it's the SIR-SAT1. My dealer installed it just in front of the Tele-Aid antenna, and it's really unobtrusive. It also lacks the big "SIRIUS" advertising on the outside. (I have a thing about wearing people's ads on my car without being paid.)
Note - there are competent people on this forum who have good reasons to dislike this sort of install from a technical perspective. You would do well to search for Scorchie's comments about Sirius installs on here before you make any decisions as to how to install your own radio. (I have several radio licenses in my pocket, so I'm not skittish about doing fault isolation if something's not exactly right.)
Did you tell the dealer you wanted that antenna or is that what they are installing?
Anyway, the MyFi gets a consistent 3/3 satellite signal and a 2-3/3 terrestrial signal in its inside location. XM receivers allow you to separately measure satellite and terrestrial repeater signal strength - don't know if Sirius receivers have that ability. The only time the satellite signal dips to 2/3 is when I'm heading south and the mass of the roof gets between the antenna and the satellite. So, if you're having trouble getting a good satellite signal for your Sirius setup with a Terk XM antenna, it could be that there is enough difference between the XM and Sirius frequencies to cause problems. Or, I suppose, it could also be that the Sirius satellite(s) just don't put out the signal of the XM satellites. I don't know.
I'm tempted to call this another example of how DCX bet on the wrong horse when it locked us into Sirius for integrated satellite installations - but since I don't really know much about Sirius, I won't.
There's a pronounced channel all of the way around the window, presumably to facilitate water drainage.
