E-Class (W211) 2003-2009
Steering Wheel Shakes?
Old Feb 24, 2005 | 04:49 PM
E500Sports's Avatar
Mercedes E500 Sport
I just purchase a 03' E500 Sport from my friend and it has 27k but I notices when I'm driving from 25-50mph the steering wheel starts shaking alil, like is vibrating. It seems to be ok once I'm up to 60mph but everytime I'm driving in that speed range its shaking.
Does anyone here know what might be wrong with it or had the same prob?
thanks
Old Feb 24, 2005 | 04:58 PM
steph280's Avatar
Tesla
I noticed slight vibe on our brand new 05 so I will bring it back to dealer soon. Usually these are just due to out of balance tires.
Old Feb 24, 2005 | 05:42 PM
yahooe500's Avatar
2005 E500 Silver/Charcoal
I have vibration on my 05 at 40 to 60mph. Two different dealers said it was out of balance. Problem still not fixed. It may be the Conti's. Switching to Michelin's PS2's when they wear out..
Old Feb 24, 2005 | 06:28 PM
E500Sports's Avatar
Mercedes E500 Sport
So can I just bring it in to Mercedes and have them check the balance? would they charge? or can I just bring it into DISCOUNT TIRES?
Old Feb 24, 2005 | 06:34 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by CarboyCLK
I just purchase a 03' E500 Sport from my friend and it has 27k but I notices when I'm driving from 25-50mph the steering wheel starts shaking alil, like is vibrating. It seems to be ok once I'm up to 60mph but everytime I'm driving in that speed range its shaking. Does anyone here know what might be wrong with it or had the same prob? thanks
It’s more than likely that they need to be balanced however, if you have Michelin Pilot Sport A/S tires, MB removed them from their “approved list” because of problems with vibration, pulling to the right, etc. due to tread design - reference: MBUSA Bulletin P-40_10-43 JAN04.
Old Feb 24, 2005 | 07:25 PM
Brav's Avatar
07 M6, 05 Noble, 01 S4, Smart ForTwo
I'm on my 2nd set of wheels and 3rd set of tires, as well as "camber bolt" dealer mod. still pulls to right. I'm gonna lemon it if they cant fix it.
I had vib. problem too. tire balance.
Old Feb 24, 2005 | 07:37 PM
MBE55AMG's Avatar
'03 Yukon XL Denali, '06 Eclipse GS
I believe this is an alignment issue. I recently had a new set of tires installed, was offered an alignment test (but declined), and I noticed vibration in steering afterward.
Old Feb 25, 2005 | 10:12 AM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
All of the possibilities mentioned are very possible (except the alignment). Bad alignment would not cause vibrations at slow speeds, but if it were bad enough to make the car shake, the car would not even come close to running well on the highway.
One thing that needs to be looked at is that there might be a bent rim. You never know, all it takes is hitting a huge pothole or clipping the rear right tire when turning. A slightly bent rim will give you the "out-of-balance" feel.
Tell us what you find out; luckily my car is fine with both sets of summer or winter wheels/tires.
Steve
Old Feb 25, 2005 | 10:17 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Also, look for a stuck rock in your tires. This can weigh the same as a balance weight and throw it off..
Also, Brav, let me know what happens. I hate my pull to the right.. I HATE it..
