Bulletins 207 coupe & 212 sedan
#228
Received 4,435 Likes
'71 Pinto
#229
'71 Pinto
Recall 2015020001 FEB15 – 2013-2015 212, 218 secondary rubber hood seal may not be secured properly. May temporarily adhere to engine hood and drop making contact with exhaust system should the catalytic converter be hot, there exists a potential risk of fire. Dealer will install additional retaining clips. Approximately 147,224 vehicles affected.
LI35.31-P-060795 FEB15 – 212 wagon as of 1/1/14 production rear axle howling noises 50-70 mph, replace rubber mounts to rear axle differential.
LI72.12-P-060888 FEB15 – 218 as of VIN A133492 up to A138257 rear window wet weather squeaking noises, replace inner sealing rail.
LI72.10-P-060913 FEB15 – 212 with Bang & Olufsen BeoSound AMG (code 811) creaking in area of mirror triangle, replace triangle cover.
#230
'71 Pinto
Recall 2015030005 APR15 – 2012-2015 218 (CLS) rear side marker lamps may not illuminate according to specifications, dealer will SCN code rear SAM. Approximately 30,041 vehicles affected.
LI83.30-P-061224 APR15 – 212.095/098/298 (Hybrid) AC has insufficient output or none at all, replace HV battery. Refrigerant circuit shutoff valve at HV battery has hairline crack.
LI68.10-P-061068 MAR15 – 218 instrument cluster noise, dealer will apply felt to IC facade.
#231
Engine Knock???
Quote: Konigstiger
LI03.10-P-052286 SEPT11 knocking noise from engine, inspect cylinder walls for scoring if found engine must be replaced. Affected vehicles are mostly production dates from 8/10 to 11/10 but might be outside this range situation was corrected as of engine # 2729xx 31932895 & 2739xx 30441186.
Dan, Could you possibly send to me the above mentioned TSB. I think my Engine #272980 31573692 may be experiencing that knock mentioned.
Any assistance would be helpful.
Thanks, Rich
Thanks, Rich
#232
'71 Pinto
LI82.61-P-061310 APR15 – 212 with Becker MAP PILOT (509 or 508) when vehicle is driven on an uneven surface or glove compartment is closed while MAP PILOT is in use, LVDS connection is reinitialized – message appears “Navigation is being activated. Please wait…” perform software update.
#233
'71 Pinto
LI82.61-P-061420 MAY15 – 212, 218, 117,156,166,172,204,207, 242 with code 508 or 509 Becker MAP PILOT not recognized, fails to boot up, hangs up. Affected part # 1669008912 containing navigation module 1669009012 update interface and navigation software + firmware.
LI09.40-P-061542 MAY15 – All models with engine 276DELA (E400) rattling noise from the engine area under partial load, noise is normal. Valve disk of the wastegate in the turbocharger vibrates in the valve seat, when the wastegate is slightly open (partial load operation) and causes a rattling noise. The actuation of the wastegate can be changed via Xentry so that it remains closed for longer in partial load operation together with SCN coding of the engine control unit however, this change can lead to light hissing noises from the turbocharger.
Service Campaign 2015050005 JUN15 – 212 (e250), 166, 204.9 with 651 engine (4 cylinder diesel) replace timing chain tensioner sealing ring. Variations in material tolerances during certain production period could lead to loosening of the chain tensioner as well as an ineffective gasket seal for engine oil. Approximately 814 vehicles affected.
#235
'71 Pinto
Service Campaign 2015060006 JUN15 – 2015 212, 218 heat shield may have been installed by mistake on left side of engine leading to clearance condition, dealer will check/remove. Approximately 5 vehicles affected.
LI82.10-P-061580 JUN15 – 212 residue on interior of headlamp assembly plastic emissions produce transparent coating on headlamp lens, clean inside lens (no mention of LED).
LI07.04-P-061777 JUL15 – 212, 207, 218, 166, 221, and 251 with 642.8 engine changes to limp mode, absolute pressure sensor instead of a relative pressure sensor may have been installed. As of MY13 (code 803) absolute sensor is used.
#236
'71 Pinto
LI82.85-P-061863 JUL15 – 212 with code 432 up to VIN B177740, 218 up to A153241 when multicontour seat button on the COMAND controller is operated central display switches itself off, replace controller.
LI54.30-P-061864 JUL15 – 212 as of VIN B085484 up to B177229, 218 as of A141977 up to A148184 assistance graphic can freeze if a Distronic speed is set and then immediately cancelled, perform control unit programming of instrument cluster.
#237
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
2010 E350 Luxury Sedan, Engine 272 (V6)
Transmission not shifting?
Have noticed if I am going down an incline at 30 MPH for about 1/2 mile and then get on level streets, the transmission doesn't shift to a higher gear as it used to.
It seems that last time even when I used paddle shifters to shift up, the indicator showed a higher gear, but it didn't seem like it.
Have read that there are problems with the 722.9 NAG2 (7G-Tronic) transmissions, but not sure which I have. The Data Card shows 722906 02 473909 for a 2010 E350 with Oct. 2009 build date.
Haven't really noticed it in my other driving.
Thanks!
Thanks!
#238
I'll add to this with a general observation that may, or may not, be relevant:
My experience is that the so-called "transmission learning" may not be helpful at all.
Over the 4.5 years of my 2011, I have on multiple occasions complained of hard (fear of damage) shifts when going up a gentle rise. No fault is ever found, of course, but usually the transmission is reset to default and the problem is gone. Then, over the months, the damn thing "learns" my driving and starts pounding the transmission again!!! I then go through the same cycle with service. I'm sure this would be different for each individual driver.
I wish I could get a reset and then turn off "learning!"
#239
'71 Pinto
Service Campaign 2015080001 AUG15 – 2015 212, 218 rubber seal on top edge of the secondary bulkhead in engine compartment damaged by supplier during production, dealer will replace seal and four retaining clips. Approximately 209 vehicles affected.
LI54.10-p-062091 AUG15 - 212, 218, 207, 204, 172, 231 with code B03 (ECO start/stop) without 4U7 (voltage dip limiter) head unit display fails shortly after vehicle starts to move in addition, following fault messages may display: Release Parking Brake, ESP-Service Required. Check/replace backup battery coupling relay.
LI72.20-P-062120 AUG15 – 212.2 as of production 12/15/14 up to 3/31/15 noises from liftgate latch area, only closes to first latch position, Liftgate Open message in IC > 6 mph. Replace liftgate latch.
LI88.20-p-062054 SEPT15 – 218 wind noises at windshield between approximately 55-75 mph. Tape transition between surround and bumper if noise is gone, caused by airflow displacement parts are not expected to be available before NOV15.
#240
Thanks Konigstiger.
My '14 E250 (40K miles) had the intermittent PB warning lamp issue, which I never seen, but the wife did a few times. Of course I blamed it on her touching the PB somehow. Anyway, my dealer did work on it and replaced the relay as indicated. Still testing this fixed, since it was an interment issue.
Interesting enough the service tech also has a '14 E350 which he also stated his wife noticed this issue, yet he never had. Guess we got to trust our wives a bit better when they tell us the strange happenings and gremblem's![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#241
Yes, not certain why they issued another bulletin rather than revision but looks like they added designo trim and clean point 8/11 validation (claim vehicles produced 8/11 > are equipped with modified trim).
This bulletin applies to your vehicle – within VIN range & datacard includes 873 (seat heater for left/ right front seats) have dealer check it.
#243
'71 Pinto
#246
'71 Pinto
Service Campaign 2015090006 OCT15 – 2015 218 (CLS) transmission control module does not correspond to current production configuration, dealer will update software. No mention of related symptoms. Approximately 115 vehicles affected.
#247
Could you bring me up to speed on anything that effects my 2013 E350 4Matic? WDDHF8JB9DA670894.
Thank You
Thank You
#249
'71 Pinto
LI82.85-P-062498 OCT15 – 2015 & 2016 207, 212, 218 disk plays from the beginning when COMAND (531) unit restarts instead of last point reached, update software.
LI82.60-P-062473 OCT15 – 2015 218 (CLS) Audio 20 head unit (1) Intermittent restart while driving, update software, (2) Partial startup/will not restart, replace head unit.
LI42.10-P-062555 NOV15 – 207 front brake juddering “complaint”, cause thickness of disk. Replace linings and disks.
LI42.10-P-062556 NOV15 – 207 rear brake juddering “complaint”, cause thickness of disk. Replace linings and disks.
#250
Interesting
I had a couple of cars where the CD would go back to the start of current song when you started the car. That was nice as you did not start in the middle of a song.
