Major Engine Failure
The light came back on Tuesday night so I brought my car back to the dealer on Wednesday, 1/6/10. My service advisor assigned the shop foreman to my vehicle. Later that evening he told me that they saw that my car registered 30+ instances of various errors including emissions alerts, fuel system failures, and ignition issues. They were so concerned that a regional maintenance representative from Mercedes was traveling to the dealer today (1/7/10) to work on the car.
I'm planning to visit the shop tomorrow to obtain a progress update.
Has anyone else experienced a similar problem?
this fault code had a cascading affect and kicked-off a variety of other codes
my service advsior told me that my W212 was the first to come in with a check engine light and since it has very few miles, MB HQ wanted to diagnose and be part of the resolution. if it were a supplier related problem, they would initiate a recall, but this one seems specific to my vehicle for now
part is arriving this morning and should have her back this evening!
Let's hope this fixes the problem. Good luck.
I'm glad the tech's fixed it. That really shouldn't be any surprise as the car is in waranty and the E classes have very few BIG issues if any.
i REALLY hope this is the root cause of the check engine light and that another electrical or physical failure doesn't come up after the purge valve repair
See the owner's latest posts. I would worry about driving the car as well and would be on the phone to MBUSA CEO re: a loaner. This is NOT the type service you expect from M-B.
I'll see what they say about resolving this sooner, otherwise, the discussion will move into compensation and a long term loaner.
For those who are upset about the title of this thread, it is named after what my service advisor initially diagnosed the problem as, prior to narrowing down the slew of issues to the faulty purge valve.
- star diagnosis system (SDS), connect & disconnect
- recode signal aquisition and actuation control unit (SAM)
- perform service campaign#2009110003, connect battery charging, use sds recode front SAM
- purge valve intermmiter fail. ran short test got code 1077, purge flow of the evap system too high, pinpoint test purge valve found intermmiter fail.
hopefully, everything is fixed now.
