Sponsored by: CARiD
Old Jun 24, 2015, 05:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior
Print Wikipost
Illuminated door sill installation
Old Oct 6, 2010 | 09:42 PM
vermont's Avatar
E350 W212 Indium Gray
Please help, just bought OEM Illuminated sills and it doesn't come with installation instruction. Anyboby have access to mercedes service so I can have a copy. Did a search and only found one for w204.
Thank You
Old Oct 7, 2010 | 07:30 AM
hyperion667's Avatar
2012 CLS63
have fun with THAT one......LOL........
from what I understand the entire door must be disassembled for the sills
to be installed, that's why they do it in Deutschland when they're building
the cars, and not at VPC's or dealers..........
Old Oct 7, 2010 | 04:23 PM
Johnny Mo's Avatar
'11 E550 4MATIC, '07 Suzuki SV1000S
Door sills
Had mine done at the dealership, but I will see if I can get a copy of the instructions, maybe wifey can pull a few strings...they gave me A-pillar instructions before so I don't see why not.
Old Oct 7, 2010 | 04:42 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
That's not correct.
But the OP will need to get 12 volt inverters (unless they came with the sills.)
To the OP, check here for instructions for an aftermarket illuminated sill install (click on the file link at the bottom): http://www.formymercedes.com/mb_resu...l+Replacements
Also, you might want to pm MBWorld member "Shardul." I removed my factory installed illuminated sills and gave them to him. He installed them on his E55. I left the inverters in the car and so he had to get some new ones.
Old Oct 7, 2010 | 07:11 PM
2012 CLS63
sorry guys, I am lame in this info department......
Old Oct 7, 2010 | 07:25 PM
97W202's Avatar
2006 C230 6speed/14 C63
no more than I am lol
does anyone know or can point me in the direction ...
DO they have illuminated door sills for the w203?
Old Oct 7, 2010 | 07:31 PM
220S's Avatar
Here: http://www.formymercedes.com/mb_resu...0Sill%20Covers
Installation guide: http://www.isynergyinc.net/mb/sill/
Also, again to the OP: here's a thread that also might be helpful re: install: https://mbworld.org/forums/e-class-w...installed.html
Old Oct 7, 2010 | 07:54 PM
vermont's Avatar
Thank you for all your reply. But the one I bought was an OEM mercedes, not from formymercedes.com. There is a difference between the two. OEM is uses EL light vs. LED for the other one. The mercedes comes ith a black box and 2 inverter. Installation looks fairly straighforward, just to fugure out where to plug one wire to get signal from the door. I don't want to splice the wire of the car, from what I see, there is a place to plug it.
This is the sill that I got http://valleymotorsmercedes.oemdeale...2577_31678.php
Old Oct 7, 2010 | 07:58 PM
ipp's Avatar
ipp
W166 ML350 BT
illuminati!
Old Oct 7, 2010 | 08:19 PM
220S's Avatar
I realize that and it's why I asked if it came with the inverters. I only referenced the formymercedes.com product to maybe help you figure out the install process.
Again, contact 'Shardul' since I gave him my sills (but kept my inverters.) He installed his on his E55. I'm sure he can give you some pointers.
Old Oct 7, 2010 | 09:27 PM
2012 CLS63
look forward to seeing the completed installation....
I'm expecting them on my car this November........will share.....
hope they're LED's....
Old Oct 7, 2010 | 10:04 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
Nope. OEM is EL. That's why the need for the inverters.
Old Oct 7, 2010 | 11:46 PM
Beausoleil's Avatar
E350
Thank You
I know you said you found instructions for W204. Were these the ones and do yours look very different?
They are pretty detailed with photographs and might be enough for me to think I could take the job on in a W212 maybe after confirming first (with your dealer or perhaps on the forum) that the areas you need to connect to are in the same place. Acknowledgement to et0609 for the pdf
File Type: pdf
