Getting remote start
$1150
Holy *****!!!I wish I was rich
Will this be incorporated into key fob or will you have two?
Seriously I wonder if it works with Benz keyless go. And I thought the MBRACE app was cool.
Enjoy the toy we all wish we had!
-The unit is the one from mid-city engineering.
-It works perfect and as advertised.
-Uses existing key fob to work (I have keyless go) so same effective operating distance
-One click of the panic button and the car powers up (electronics and lights come on then 5 sec later the engine turns on).
-To drive, just walk up to the car and open the door as normal with keyless go, sit down, press the start button once (pressing anything else shuts off engine as a security feature) and off you go.
-Shuts off after 15 minutes if you dont get into the car.
Took the dealer 2 days to figure it out as this is the first E class they've done. They had done it on a number of S's and apparently the process is different. Not a big deal though as I had a no-extra charge loaner
Apparently - you can also add a module to this that allows the iPhone feature to work which I didn't get.
If you don't mind, I'll copy and paste this to send to my SA to blow her mind!! lol
how does this using the panic button? does it still panic when and if you need it too?
So did you but the unit from Mid City and take it to the dealer or do they have these in stock?? Does it void any warranty??
Thanks.
-Not sure if there is a way for panic alarm to work any more. I'll check the instructions
-You just press the panic button once just as you would press the unlock button. This is a huge improvement from the one in my MDX where I need to press lock 3 times in just the right timing or it doesnt work, and I then need to use the actual key (imagine the horror) to unlock the drivers door.
-Correct - range is same as FOB
-Didn't order from mid-city - although when I filled out their online form (after being directed there from another forum here) they directed me to my own dealer.
-Warranty not voided
my truck fob you have to press the button twice, seems like a good idea.........
damn I want one of these
