Sponsored by: CARiD
Old Jun 24, 2015, 07:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
Accuracy of In-Dash Tire Pressure Monitor?
Old Aug 14, 2011 | 08:12 AM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Lol.
Old Sep 5, 2012 | 01:40 PM
BenzV12's Avatar
W212 FL
I was looking for this topic and glad found it
Well, here is my input about accuracy of the indicator . It is working very well
The image shows what happened yesterday right after turning off the audible amber warning during my driving .
Long story short , when I parked my car I visually checked all the tires and all of them seemed up to notch . However, my mind was not easy because of that tire pressure warning
Today , I checked all the tires by gauge , fronts were equally 30 psi (34 psi my last inflation ) , rear left 26 psi and right rear 32 psi
Both rear tires were inflated 2.5 bar , equally 38 psi .
As you see right rear lost pretty high air , I don't know why but I think it was what triggered the warning message .
So, what I don't see is normally you should be able to view pressure readouts for all the tires but mines don't show them anymore , I dunno why
So, moral of the story please check monthly or every 2 weeks with your tires are cold and if you see an audible warning about tires please do not ignore it
Attached Thumbnails Accuracy of In-Dash Tire Pressure Monitor?-image1255.jpg
Old Sep 5, 2012 | 04:13 PM
norcal_cyclist's Avatar
2010 E350
Originally Posted by marka5083
I wonder if others have experienced a discrepancy between the in-dash tire pressure monitor and actual tire pressures.
I find that the monitor is consistently off by 3-5 PSI even after resetting the monitor several times.
However, it may be that this is within normal operating parameters as the monitor may not be designed to be precise, but to only be a backup/failsafe to accurate manual monitoring.
Would be interested in other opinions.
Thanks.
Mine is extremely accurate - so much so I am thinking about installing a similar system into my race car. I use a very expensive and accurate tire gauge and it is spot on with my sensors.
Old Sep 7, 2012 | 10:56 AM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Mine appears to be fairly accurate. I have pencil type and dial type gauges and they agree with each other. The TPMS in car is usually within one lb. or so of what my gauges show. But that is after driving for a few minutes. Sometimes the TPMS TP's will be the same for both tires, but not too often. Never more than a lb. different though.
My car has different TP's for front and rear.
I do check my tires with my gauge at least every two months.
Old Sep 7, 2012 | 01:26 PM
RSIKR's Avatar
2014 W212 E350 4M
I have both digital and dial gauges, TPMS is always within a pound.
