Waiting to order a 2012 E550 4M but nervous!
I have been searching for any reports on the 2012 but it may be too early yet since it just was released. I have had friends telling me it's not a good idea to buy a car with major changes in the first year with no track record. I keep my cars for a few years and yes I've thought of buying the extended warranty. But, that kind of defeats the point I'm concerned about which is service reliability on the new 4.6L turbo/Direct Injection engine and new transmission changes to match.
I would appreciate anyone's input to help me make a decision on whether I should wait another year or go ahead as planned.
Thanks again.
Toban
Here is a link to some photos of some badly clogged up valves in DFI engines:
http://forums.quattroworld.com/rs4b7/msgs/19166.phtml
Here's my concern. I want the newest engine etc as I think down the road, the used car customer will want this feature in a car. This is why I've been waiting for months. It's a bit of a crap shoot I think juming into the first year engine. Although, one poster did comment the CL has had this engine through 2011. I wonder if there's been any problems with the engine? Why does a DI engine carbon up as one poster commented on?
Toban
I was considering taking my wife's 2011 E550 from her & buying her a new car, but once i tested the new 4.6L, i knew i had to have it.
You'd be crazy to buy the old one.
The carbon mostly comes from valve overlap. I know turbo motors are less susceptible to carbon because there is little to no valve overlap. Hopefully MB either eliminated valve overlap or installed a downstream injector.
More than likely though, the new 4.6 will suffer from carbon build up. For most people, it will not be perceivable until 50k or later
One thing is for certain, NO fuel and NO additive can prevent carbon build up. Unless of course MB has a downstream(I guess it would be upstream, actually) fuel injector
Toban
You know you have it when you get missfires on cold starts or missfires in the upper rpm range. If you ignore it, your rods will take a hard right exit out of the block!
By the time it affects you, your warranty is done. Getting rid of the carbon build up is a nightmare. I have done it on a V10 S6 and it was a nightmare(did I say it's a nightmare?). TO get rid of it, you have to completely remove all the intake components down to the manifold and scrub it manually. Each port on the S6 I did took 45 minutes or so. This stuff is tougher than it looks.
Here is some pictures of the S6
Before:
After:
Torque: 391 ft-lbs. @ 2800 rpm
Horsepower: 382 hp @ 6000 rpm
EPA mileage est. (cty/hwy): 15/23 mpg
New 4.6:
Torque: 443 ft-lbs. @ 1800 rpm (wow)
Horsepower: 402 hp @ 5000 rpm
EPA mileage est. (cty/hwy): 16/26 mpg
The new engine is one of the main reasons I bought this car vs a 2011, more power and better fuel economy. Sure there may be problems with DI, but from talking to my friend who works at MB they made some changes to the DI system for the US because of our fuel "quality" or lack there off. He didn't say what they did or he did and it was over my head.
Edward
my 550!!!
