2011 E350 4MATIC SEDAN Winter Tire
I have the same tire but on 18 inch - personal preference. I researched the matter and 17 and 18 tires are fine with this vehicle. MB published a document (in German) with all engine/versions of this car with acceptable tire and wheel combinations, and 17 and 18 inch are fine. 16 inch was not listed for our NA version though.
Last edited by rovermark; Nov 26, 2011 at 03:03 PM. Reason: correction - see below
under Typ212
VA = Vorderachse (front axle), HA= Hinterachse
We are "Variante 3" - "Hinweis" (Footnote) 1 states that no modification or change in documentation is needed, and footnote 6 states not possible with the E500 4Matic.
actually, when reading your post, the 17 inch tire combination is slightly different (225/50/R17 vs. 245/45/17 in that document), so I take everything back - I don't know.
The tire diameter is less than 1% different from OEM. He will be fine.
Highly rated on their surveys,,and winter in NY can be a trip
.Price is very reasonable as well.
I prefer to stick to the exact stock sizes, even in winter, just so the car doesn't look funny with skinny tires. Your 225/50/17 will probably work great for you...and i'm sure they are half the price of a 245/40/18 set-up.
OEM Tires are 245/40/18 Continentals. I had seen posts describing the use of a staggered set up of 245/40 and 265/35/18s but I now have reason to believe that this set up is for non 4Matics. I just want to confirm this. I can appreciate that a half-inch difference makes a big difference...
I do not want to damage the car in anyway. I accept responsibility for the purchase. If I need to I can sell the 18x9" wheels locally and recoup my investment.
Feedback is welcome. Thanks.
