Sponsored by: CARiD
Aftermarket Wheels / Tire Tread Wear Question
Old Dec 12, 2011 | 12:24 PM
EmE247's Avatar
Current: 2011 W212 Previous: 2008 W211 2006 550 2001 Rover 1997 W210
Just wondering if anyone that knows about tire tread readings could help me out.
I have aftermarket 19's on my ride lowered with H&R Springs. Never got around to doing an alignment / camber adjustment...
So got my car back after Service A and it seems that they did a tire tread reading on my tires...
Left Front (Outside/Center/Inside) 6.5/7.7/5.7
Right Front 6.4/6.9/4.7
Left Rear 5.8/6.3/6.2
Right Rear 6.2/5.8/5.5
Seems that the insides are wearing a bit more than the outsides.
Should I get an alignment/camber adjustment done or is this just a minor difference that won't affect tire wear much? Other thoughts would be appreciated...
Old Dec 12, 2011 | 03:34 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Well the numbers dont lie,,I would because it appears your cutting into the service life of the tires.
Old Dec 12, 2011 | 03:43 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
It looks like your alignment is out of whack.
Old Dec 12, 2011 | 04:30 PM
Busta Riles's Avatar
1969 280S, 1991 300E
Rule of thumb on lowering: Always get an alignment done immediately after lowering. Even without getting a camber kit, adjusting the TOE makes a huge difference for tire wear.
Every car i have owned in the past 15 years has been lowered. Good choice on H&R...their ride heights always seems to be perfect on every car, IMO
Old Dec 12, 2011 | 04:48 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
The tires that are high in the center are likely over-inflated. The ones lower in the center are under inflated. An alignment is critical after changing any aspect of suspension geometry.
Old Dec 12, 2011 | 07:29 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
Typical to lowering especially when not aligning and getting camber kits.
It is very much a problem. One time to Vegas, in my old lowered car (same thing you did, springs, no shocks, alignment was out of whack and no alignment shop seemingly "could align a lowered car" and some "normal" lowering-camber), the inner walls got eaten up so much, I had a blowout while going 80 or so. Fortunately it wasn't a disaster in any way, aside from being stranded in middle of the desert for a couple of hours, having to call everyone in my family at 1 AM to see if anyone has Triple A, waiting for Triple A to trek down to the middle of the desert, riding home with the Tow guy, having to get the car towed to a new tire shop the next day to buy tires, etc.
Old Dec 12, 2011 | 07:44 PM
CEB's Avatar
CEB
Don't you mean that the other way? Overinflation leads to higher wear in the center while underinflation leads to increased wear on the outside and inside - unless by"high" you meant higher wear etc.
Old Dec 18, 2011 | 12:45 PM
Yosheego's Avatar
2011 E550
I just had my car lowered with links...anybody have an idea how much it would cost to do the alignment at the dealer?
Old Dec 19, 2011 | 02:03 AM
BM2BZ's Avatar
w212 E550
no matter where you take your car to do the alignment, don't go to sears! they screwed up my bmw before .
Old Dec 19, 2011 | 08:41 AM
ImInPA's Avatar
lol....yes....sheeesh...I meant just the opposite. Tire inflation will will cause the type of readings he is seeing.
Old Dec 19, 2011 | 08:38 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
yes...always get a 4 wheel computerized alignment done after suspension changes. By the looks of your numbers, you got negative camber and/or toe in. The oddity is the left rear, which indicates its either positive camber and/or toe out.
