E350 Agility Control Question
The agility control is purely in the valving of the shocks, and not electronically controlled, correct?
Therefore, if I upgraded to coilovers, I won't run into sensors going crazy or warning lights going off on my dash right?
Sorry if this has been asked and answered. I've only found anecdotal evidence of my assumptions above via the search function.
BTW, have any of you who have leased and lowered your vehicles run into problems with dealerships trying to void your warranty even if you don't go in to service with a suspension related problem?
My question more specifically is whether or not the shock damping is variable because of the use of magnetorheological fluid which requires a charge or magnet to be applied by the car electronically, or if the variable damping is purely a physical function of the internal valving in the way of Koni FSD's.
My confusion arises in large part from the fact that in certain other countries, the E sedan has driver selectable shock damping, whereas in the US, we have no such option. IIRC, in the US, the comfort and sport mode button control only the engine and transmission characteristics, and not the suspension settings. So, the possibility exists that in the US the suspension is electronically controlled, albeit through some "big brother" algorithm that we have no control over.
As an aside, if the above is true, man those Germans must think we here in the US are total retards. They took out stoplight engine deactivation on us because they thought we were too dumb to adapt to it right?
No dealership ever has "voided the warranty" for any single mod. The warranty can only be "voided" by the manufacturer and would have to involve a significant amount of mods as to affect virtually every system in the car.
Mitsubishi went to some track meets and voided the warranty on cars that participated in races. BMW voided the warranty on one 3 series where the owner had botched electrical, suspension and engine mods. BMW showed that every failure to date could be traced back to one of the mods.
That said, a dealer can (and should) refuse warranty service on a failure caused by a mod. For suspensions this could include wheel bearings, some drivetrain components and rattles and squeaks.
Much of this depends on your relationship with the service department. If your relationship is good and the dealership is reasonable (most MB dealerships are) then you shouldn't have an issue.
Some dealers do make notes in the system about mods so future problems may be refused warranty service even if the mod has since been removed.
I do see people here who have installed coilovers and have not heard of any complaints regarding sensors or dash lights going off, so that's a good sign.
