Sponsored by: CARiD
Old Jun 24, 2015, 07:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels and Tires
Print Wikipost
"check tire pressure"
Old Jan 25, 2012 | 11:41 AM
ghstudio's Avatar
Mercedes e350 BlueTec
When I turn off my 2011 e350 bluetec, I keep seeing a message..."check tire pressure" (or something like that) with tire pressures showing. The pressures are within 1 pound of the recommended tire pressures shown on the inside of the fuel cover.
Do others get this message? Is this some sort of error or is this normal because it doesn't make any sense.
Old Jan 25, 2012 | 11:52 AM
dfordham's Avatar
2014 E350, 2012 SL550
The car doesn't know what the recommended pressure is. You have to tell it what pressure you want it to consider normal by going through the TPMS reset procedure. When you have the tire pressures where you want them, which may be where they are now, do the reset and the TPMS system will use those pressures as normal.
Regards,
Don
Old Jan 25, 2012 | 12:07 PM
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
+1 to what Don said. Let the car sit overnight, adjust all the tire preassures to what you desire them to be the following morning (I go with what is on the fuel flap) then reset the tire pressure monitor and it will ask you if it should take the current measurement as the new base values. Say yes and you should be done.
Old Jan 25, 2012 | 12:20 PM
ghstudio's Avatar
I keep discovering things about this car....and I'm a techie.
One has to wonder how the average owner ever figures out all the non obvious features. If you are reading this, you are not the average owner
Old Jan 25, 2012 | 12:31 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Regards,
Don
What they said. Dealers do a very bad job of prepping the cars and adjusting the pressures. Cars are shipped with higher pressure to minimize shipping damage, flatspotting and losing pressure over time.
The dealer is supposed to set the pressure and reset the system to the proper baseline. They don't, so what you are seeing is a drop from whatever value it was set to at the factory. That drop can be time dependent (1psi a month) or temperature related (1psi for every 10 degrees of temperature)
Old Jan 25, 2012 | 12:41 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
+1 on all of the above.
