- Mercedes Benz E Class How to Reset Tire Pressure Monitoring System (TPMS)
Step by step instructions for do-it-yourself repairs
TPMS for aftermarket wheels?
Just buy a second set of sensors. While the initial cost may be higher, it'll be cheaper in the long run.
I'm looking for the part number or frequency or whatever specific type TPMS we need in our w212s.
swapping is not the best option..
Alternatively can the TPMS indicator/warning be turned off? that may be an option as well as i dont mind manually checking my tire pressures like a caveman
2.Just don't activate TPM mode.
The part number for W212 (and for this matter for most late model MBs) is 433 MhZ sensor (not any 433 will do as they produce different signals) made by Schrader part number 28214. TireRack sells them for only $62 each - part number is S086 28214. I bought four sets from them - plug and play. Easy.
Take look around page 232 Here http://www.mbusa.com/vcm/MB/DigitalA...10_e_sedan.pdf
my MB service advisor told me there is no way to deactivate the TPM
mode since it is a mandatory safety feature, just like you cannot
deactivate the seatbelt warning. I don't know if he is correct.
He wasn't sure what warning you'd get if you ran tires without the monitors.
Would a warning light just stay on all the time or would it then go to a higher level warning---audio or flashing light???
Anyone run a W212 without the monitors that can tell us all what happens?
so you cancel it and the message goes away/ doesn't come back until
the next time you start the car?
Nice to know.
P.S. is your vehicle a 2007 E? Anybody know what happens on W212 as it may
not be the same?? Thanks
