Had it up to here with brake dust?
Then there's the brake dust 'situation' that has plagued me and possibly every other Mercedes owner for all of eternity. My '97 E320 had the issue as well and on that car if the brake dust wan't cleaned off regularly it had a corrosive effect on the wheels. The '10 E550 has an even more prolific dust production problem but the corrosive effect is TBD. Compounding the problem is that I like to keep my car clean and neat -- don't we all? After a loving hand bath it takes all of 5 miles of driving to lay down a new layer of oily grime.
Spent some time on both email and telephone with the good folks at Akebono to find out why I can't purchase ceramic disk brake pads for my specific vehicle. Learned that the E350 owners have ceramic pads available but apparently the population of E550's (Sport in particular) is too small for them to manufacture ceramic pad for this model. S.O L.
Does anybody out here know of brake pad options for this model that would reduce or eliminate the dust problem? Ceramic, abestos, metallic, fiberglass -- I don't care I just want cleaner wheels.
BTW, I acknowledge and understand that Mercedes has chosen the pads and materials in them for a reason. I can live with any resultant change in braking performance if I could trade dust for money.
Any suggestions are welcome. Please save me and all of us from this plague.
"Are you so stupid that you would actually sacrifice braking power to keep your wheels clean?"
Still shaking my head on this one.
The AMG wheels on my 2012, stay cleaner than any other car I've ever owned. They are surprisingly easy to maintain.
There is an old thread somewhere here where it is mentioned MB changed the pads, I believe in '11 - not sure.
With my last Benz, the wheels were black in no time, especially the fronts.
No expert here but, perhaps it's possible to update your pads with the newer MB type.
All you say about the car is as I see it including the brake dust. I had a 2011 E350 and that car had minimal brake dust but the 2010 E550 sport that I now drive has a serious issue with it especially in the front. I asked my MB dealer parts if they have a better pad option but according to them they do not.
So, I went to AutoZone and ordered ceramic front pads, only front as they did not have rear. They came in in two days and the problem is gone with no loss in braking performance.
The cost of the pads was a whopping $65 with 5 year warranty. It is their own brand name Dura...something.
Put them on myself. Super easy job, no bolts to open. Just punch two pins out and that is it (with squeezing the pistons back in).
I highly recommend these pads for performance, no dust and cost.
Just want to mention here that I would have preferred MB to install new pads in my car but they won't install other than their own parts so to fix the dust issue I had to do it myself.
One more thing. There is only one brake pad wear sensor per axle, i.e. only passenger side pad has it. If sensor is not tripped it is super easy to take off of the old pad and install in the new one, i.e. no need for new sensors.
Thanks again Arrie I'll pursue the Auto Zone suggestion and I'm still interested in hearing about any other options you have found.
Agreed--that was very helpful input, Arrie... Everyday I'm impressed w/ those who step up when called upon to lend a helping hand. There are very knowledgeable M-B owners out there who understand the value of sharing that knowledge, vice the alternative... Kudos to those who recognize this and are willing to provide positive feedback to help fellow forum members push through their various challenges/issues. EDIT: Oh, and for the record, Petep, my '12 E350 doesn't seem to produce a lot of dust either...but I do keep her clean; haven't let it go more than a week w/o a bath... I echo others that mentioned to check on pads that come on the more current models. That may be your answer!
(unless they're the same dern pads!
I stopped looking for other options as the dust issue now is solved. The rear brakes always had very minimal dust and right now I don't see the need for replacing them but will look for ceramic pads for rear too when it is time to replace them. It just seems the rear pads will last easily twice as long as the front.
It's also a way for me to bond with my baby. No cleaner needed btw if you keep on them. Good Luck.
I wash my wheels with meguairs gold class soap and some wheel cleaner (only used wheel cleaner on first application). Blow the wheels off dry with a leaf blower or towel. Then use Armor-All Wheel Protectant. It is an aerosol that you spray on just like you are painting the rim. Be liberal with the application and best to let them dry in the garage overnight. Once dry you will get no brake dust build up for weeks and it keeps the car looking cleaner.
I also used it on my W163 and W203 which made significantly more dust than the W212 and F10 (BMW) and they would last at least 2.5 weeks before showing any build up of dust. Even at 4 weeks they still looked relatively clean.
