20 Inch rims on 2012 W212
2012 E350 4Matic P2 / Sport / AMG wheel package / Pana / Lane changer / Packtronic & IS350 Sports
Hi, I a newbie at this forum...
I just ordered first set of 20 inch rims ( 20x8.5 front with 245/35 & 20x10 rear with 275/30 ) for my new
12 W212 E350 4Matic P2 / Sport / AMG wheel package /
wondering if anyone has pictures of 20 Inch without lowering the car
I'm debating if i should lower it or not....
I dont want to damage my stocks....
clmulli - thanks ... ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
its kinda high .. i might have to get lowering module .. T.T
I guess you didnt lower your car yet, hows the ride?
If you lowered it how many inchs?
2010 E350 Sport
I'm still debating lowering. If so I'm going with the Eibach Pro-Kit 1/2" front and 1/2" rear. Lowering module would be nice. You will be able to adjust your height. There are others guys here that have those that could provide better input.
clmulli - thanks again ...
I was looking into Renntech lowering module but they dont have it for 2012 yet
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
LFTW8S
2012 E350 has Airmatic suspension in sports version.
A lot of disinformation or at least misunderstanding here.
1. 2012 W212 E350s do not have (and never had in prior years) Airmatic suspension, regardless of trim, even as an option. On top of that 2012 W212 E550s no longer have it as standard either (special order option only).
2. Before going though hassle of lowering, make sure 245/35-20 that you want to use upfront will fit. You may be unpleasantly surprised.
Sport/comfort (or economy) setting(button) is not for shocks - its for transmission only. Shocks in E350s, unlike 2010-11 E550s, are not driver controlled. Sport E350s have a so called Agility control (not driver control) not Airmatic (driver controlled "somewhat"). OP maybe confused, but Airmatic and Agility terms should not be confused.
2010 E350 Sport
About the time because the diameter of the tires are the same as stock. (3MBs correct me if i'm wrong) I switch from 275/30/20 in the rear to 285/25/20 which leaves more space between fender and tire. Hope this helps.
Benzio, I wen through the same process several month's ago and these guys were great, Especially threeMBs. I went with the 20 you can see my pics and I have not lowered the car. I have a small gap and would like to lower but I have an awesome ride and I a do not want to lose the ride quality.
275/30/20 in the rear and 235/35/20 in the front with no rubbing
