Distronic and brake lights
Great long drive in our e350 wagon the last few days, and used the Distronic much more than before -- from set at 73 all the way down to 20 or so, and back up. System works very well.
But...does it turn on the brake lights when it slows? Or only when it slows a certain amount? Anyone have any idea? I know that the hold feature leaves them on. Seems it would be safer turning them on, but only when it uses the brakes rather than easing up on the throttle.
In my experience, it doesn't touch the brakes except in an emergency. Otherwise, "slowing" seems to be accomplished by reduced throttle and down-shifts.
In a computer-perceived emergency, with Distronic Plus with Brake, I will only assume the brake lights come on -- don't know how to test safely.
The way I think it works is the cruise control does use brakes when ever it needs to do so to keep car speed at setpoint going down hill or to slow behind another car with Distronic but the brake light does not come on most of the time.
I think the thinking here is that if the slowing down is at rate a manual geared car would do with only engine slowing it down the brake lights are not used. If slowing down is more aggressive then the lights come on.
To test for this is quite safe and simple to do. Go drive on a highway say 55 mph on empty road and hit the CC stalk down once or twice and see how car slows down clearly using brakes. If you hit the stalk three times very quickly, i.e. ask for 15 mph speed reduction (make sure you are at even fives before hitting the stalk) the car slows down much quicker and this time also the brake lights come on. This is how my 2011 E350 worked (without Distronic) and this is how my current ride 2010 E550 with Distronid does it.
If you test at dark you will clearly see the brake light when it comes on.
In my car, Distronic Plus + Brake, I can clearly see the RPMs pop up as it shifts down on downgrades to maintain a CC speed, sometimes more than one gear if the first downshift doesn't do the job.
I've never had a downgrade where I thought the car applied brakes. Maybe with your scheme, a quick 15mph CC change, it would feel brakes are necessary.
The question is when the brake lights come on -- when it lifts, when it applies the brakes lightly, or only when it throws out the anchor? Watching the people behind me, it seemed like the lights were late (or the people were texting...)
I doubt MB would design a system that worked counter to that.
The more I read posts about Distronic Plus, the more fascinated I am about this supurb technology. I don't have it, but buying my next car will take a bigger bite out of my wallet because of D+ or whatever it may be called by that time.
For those of you who have it, great choice!
I have yet to have it apply brakes when not on cruise in an impending accident situation. I have had it beep at me several times when someone has cut me off.
