Is there Speed Limit display on GPS or dashboard ?
Thanks a lot !
P.S. Thanks everybody for your replies ! Pretty much confirmed there is no Posted Speed Limit display. I just learned from other owners that Real-Time Traffic on mercedes GPS also needs monthly subscription --- Is this also true on 2012 models ? How useful did you find for the Sirius Traffic ? I only see real-time traffic display on major highways, not streets ---- so not as comprehensive as Google Map. Are you guys able to subscribe to Traffic only ?
Maybe just get a Garmin for Speed Limit, also possibly Safety Camera info, and Life-Time Map & Traffic. I am looking at 2595LMT, but it is not compatible with its own Safety Camera software, however you can download similar info from trapster.
Inputs ?
Thanks !
But my Garmins (and I own three of them) frequently display the WRONG speed limit.
I would personally rather keep an eye on the signs on the road than trust the GPS to tell me the speed limit.
YMMV.
Selecting the permanent display function
The Permanent Display: function allows you to choose whether the multifunction display always shows the outside temperature or the speed in km/h (USA) or mph (Canada).
X Press the = or ; button on the steering wheel to select the Settings menu.
X Pressthe:or9buttontoselectthe Instr. Cluster submenu.
X Press the a button to confirm. X Press : or 9 to select the
Permanent Display: function.
You will see the selected setting Outside Temperature or Speedometer [km/h]:.
X Press the a button to save the setting.
So this shows current speed in both MPH and KPH, not posted speed limit.
