Sponsored by: CARiD
iOS 6 Bluetooth MAP
Old Sep 19, 2012 | 11:01 PM
zaxxon's Avatar
MB
I upgraded my iPhone to iOS 6 today. I deleted previous pairing and paired again. But, still text message is not working with comand 4.5. Still Text Message menu item is grayed out in comand. Does it require internet connection from iPhone by tethering?
Old Sep 20, 2012 | 01:09 AM
ghstudio's Avatar
Mercedes e350 BlueTec
For text messaging to work in Comand 4.5, the phone needs to support bluetooth message application protocol (MAP) and while it is supposed to be in IOS 6, it's not at all clear from reports that it's working. You may have to wait for an update to 6.
Old Sep 20, 2012 | 07:59 PM
mikemargolis's Avatar
'11 E350BTC P2 Leather
I updated my iPhone 4S to 6.0 yesterday, did not have to re-pair to the car. Everything working fine, but I don't have 4.5.
Old Sep 20, 2012 | 09:43 PM
dfordham's Avatar
2014 E350, 2012 SL550
Based on observation, I think the only time Comand queries the protocols supported by your phone is when they are paired.
In other words, if you upgrade your OS and it adds new protocols, unless you unpair/re-pair, the phone's new protocol support will be unknown to Comand. The existing protocols will still work fine, but not the new.
I experienced this with BT streaming metadata. I upgraded my phone to an OS revision that supported the required protocol, but it didn't work until I re-paired the devices.
Regards,
Don
Old Sep 20, 2012 | 10:09 PM
zaxxon's Avatar
MB
Regards,
Don
OK, I confirmed that Text Message menu in COMAND 4.5 is activated with iOS 6 iPhone. Bluetooth notification should be on in Bluetooth set up. Once it's on, re-pairing was not needed and just started working!!!!
Old Sep 21, 2012 | 10:17 AM
weaveleftnright's Avatar
'12 W204 4Matic Sport
The text messaging is still not showing up as valid. Don't know what phone you have but I am on the regular 4.
Old Sep 21, 2012 | 11:41 AM
  #32
dfordham's Avatar
But your first post says you did re-pair after upgrade.
Regards,
Don
Old Sep 21, 2012 | 11:42 AM
  #33
I just re-paired mine and no luck
Old Sep 21, 2012 | 11:53 PM
  #34
pcdsl's Avatar
2017 C43
Go into your iOS bluetooth settings, then select the MB Bluetooth by clicking on the blue arrow. Then enable Show Notifications.
Old Sep 22, 2012 | 07:00 PM
  #35
dawsonjw's Avatar
250 CDI C204
Hi
mine does not have Show Notifications, it only has Sync options for the phone book
cheers
John
Old Sep 22, 2012 | 09:28 PM
  #36
mbmbmb1's Avatar
2012 E350 4Matic Sport
It works for me. iPhone 4, iOS 6. 2012 E350. Not sure what Comand version I have.
Just like others have said, delete the pairing from phone, then re-pair. Then enable "Show Notifications" as above. Restart car/Comand.
Pretty cool feature.
Old Sep 24, 2012 | 04:31 PM
  #37
mambrose23's Avatar
2018 M4 comp cabriolet, 2017 C43 Sedan, (wife)
No luck here. Have ios6 and 2) 2012 e class cars. Neither worked. Deleted phone using command system, then re-paired the phone. Went to ena
ble "show notifications" but it does not appear on phone. I went to the ios settings, bluetooth section, then looked at the connection. The only thing that appears after that is "Sync Contacts" and below that 3 favorites under the heading of "Group" No "show notifications". Am I looking in the wrong spot??
Thanks, Mark
Edit--Wife's 4s with IOS 6 does work. Had to wait a bit for the "Show Notifications" to come up on on the screen. Still waiting for the older phone with IOS 6 to show it. lol. Probably the phone...
Old Sep 24, 2012 | 05:29 PM
  #38
Mine had only sync contacts and then magically the show notifications appeared. Odd. iPhone 4 with iOS6 2012 W204 C300 4Matic.
Old Sep 24, 2012 | 06:31 PM
  #39
dsbull's Avatar
2025 GLE53 Coupe
confirmed works fine with iphone5 and ios6. i can receive text messages on command 4.5 2012 e.
would be nice to reply via command but maybe next model of e will support that
Old Oct 6, 2012 | 07:22 AM
  #40
JaCe88's Avatar
GLE 300d (v167)
I haven't tried repairing yet but does COMAND Online support using the data on the iPhone yet or is it still stuck on the DUN profile requirement?
Old Oct 6, 2012 | 10:39 PM
  #41
Scuba Steve's Avatar
None
I also want to know this. Can someone use their contacts at benz to find out?
