Subwoofer/Amp install complete!!!
Here's hoping for an answer on this as it has been an elusive topic for non-premium audio models.
I have a 2006 E350 W211, base, non-premium audio. Same question, same intention, just a different year.
Find the AGW in the left side of the trunk. In the 2006 W211, it is between the trunk arm/springs and the fender well (behind the fuse block area). May have to drill out rivets to access- if so, will need to re-rivet back in place when done.
Find and splice off of the AGW wires that goes out to the speakers (to wire in your LOC):
Left Front Speaker (+/-) green - brown/green +,- amplifier in trunk left side, 14 pin plug, pins 7 - 8
Right Front Speaker (+/-) black - brown/black +,- amplifier in trunk left side, 14 pin plug, pins 13 - 14
Left Rear Speaker (+/-) pink - brown/pink +,- amplifier in trunk left side, 14 pin plug, pins 9 - 10
Right Rear Speaker (+/-) white - brown/white +,- amplifier in trunk left side, 14 pin plug, pins 11 - 12
I will post pics of this when I complete this as well as lessons learned, for science.
AGW and wires to splice in order to add a LOC for amp in a non-premium audio version of the W211
https://www.amazon.com/dp/B09M6HXFWR...xpY2s9dHJ1ZQ==
I desperately need you to share how you got that panel for fitting the GB25s in the A pillar, good sir
I was debating fitting GB40s in the center console but I think your setup will result in a much better stereo image.
What is the resoning for not going full Audiofrog by the way?
I see alot of your posts - and all in all I just want to say thank you for all the cool stuff you share.
