Sponsored by: CARiD
Old Jun 24, 2015, 05:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Exterior
Print Wikipost
OEM kit install back up camera W212
Old Dec 29, 2012 | 11:57 PM
torjan's Avatar
E200 CDI - w212 - 2010
Dear MB, I have an E-class 200 CDI from 2010. The car doesn't come with backup camera, i decided to buy the original parts and install it my self. before I will do that can anyone give me some hin't how to make all the wires ?
This is the parts I bought:
Backup camera
Part number: A2128201897
Modulator
Part number: A2128270006
Cables
i didn't find on the net the exact model for W212, so I took the one for W164, it is the same if I'm not wrong
as you see in the picture of the cables there is:
- white cable will connect the camera to the Modulator
- The black cable has many connectors:
- The white connector with black and white wires will be connected to the Modulator.
- Fakra cable will go to the comand unit.
- There is Three remaining wires:
- Black, Brown, Red
I think that the white should be connected to the reverse light ?
The red will be connected to the + (SUM), where in the sum should be connected ?
The Brown will be connected to the ground ?
Can anyone could help to confirm this installation ?
I have already activated the backup view mode in the engineering menu
Thank you
Attached Thumbnails OEM kit install back up camera W212-backup.camera.install.w212.jpg
Old Dec 30, 2012 | 12:36 AM
golfster's Avatar
Titleist
Originally Posted by torjan
Dear MB, I have an E-class 200 CDI from 2019.
How do they look?
Old Dec 30, 2012 | 12:54 AM
BM2BZ's Avatar
w212 E550
Originally Posted by golfster
How do they look?
+1 and please post some pics .
Old Dec 30, 2012 | 03:10 AM
torjan's Avatar
loool i will do in 2019
Old Dec 30, 2012 | 04:25 AM
BenzV12's Avatar
W212 FL
Good job , nice to have skilled members on board
Old Jan 22, 2013 | 02:56 AM
torjan's Avatar
Finally I have found a solution.
Reading some forums I have found this solution:
It seems that mercedes use the same Modulator and camera for couple of here models:
W212 E class / W207 E class coupe / W204 C class.
So i bought on ebay for my car W212 E class:
Modulator : A2128270006 (for W212)
Camera: A2078200897 (for W207)
Camera to Modulator wiring harness: A2044404808 (W204)
Modulator to comand wiring harness: A2044404908 (W204)
The wiring are for a C-klass. The wiring from the camera to the modulator will work.
The second wiring A2044404908 from the modulator to comand will not feet properly.
the connector to the SAM could be not the same. the reverse light connector also could be not the same.
For that reason I have bought a Add-a-fuse to connect to SAM without cutting any cable.
and I bought a Scotchlocks to connect to reverse light without cutting the reverse light cable.
I still did not receive the cables yet. I will put some pictures of the installation.
Attached Thumbnails OEM kit install back up camera W212-camera.install.w212.jpg   OEM kit install back up camera W212-install.modulator.camera.w212.jpg
Old Jan 25, 2013 | 08:41 AM
CTDK's Avatar
W221 S550L, W212 E250CDI Wagon
its very easy in w212..
it should not take more than 2 hours..
depending on which cableset you get, some of them the cable in the green connector that goes behind the comand unit, they have misplaced it wrong from the factory.. so if its in chamber 1, then it needs to be in chamber 2.. its not certain that you will have this problem.. but if it doesnt work after installation, that might be helpfull
remember you must go into engineering mode on the comand to enable rearcam svrc..
Old May 21, 2013 | 10:19 AM
teknoboy66's Avatar
c300
Is there an actual DIY for this somewhere?
Old May 21, 2013 | 11:32 AM
torjan's Avatar
Hi techno boy unfortunately no. I bought the different parts but I need time to make the install. Once done I will post the DIY.
Old May 30, 2013 | 11:41 PM
torjan's Avatar
HI Mbworld,
I got the different parts yesterday, and now ready to install. I'm still confused about only one cable, that connect the Modulator to the Camera, I can inverse cable 1 and 2, between the camera and the Modulator (see picture 3). can any one confirm that it is the write connections ?
Attached Thumbnails OEM kit install back up camera W212-camera.install.1.jpg   OEM kit install back up camera W212-camera.install.2.jpg   OEM kit install back up camera W212-camera.install.3.jpg
Old Jun 6, 2013 | 02:50 AM
torjan's Avatar
Any one know where I should connect the reverse light cable for the E-class W212, I'm not able to find any picture of the connection on the web. thanks ?
Old Sep 5, 2013 | 04:14 AM
why_not's Avatar
W212 2009, W115 Pullman & EQC
How did it go?..
Old Sep 5, 2013 | 05:22 AM
torjan's Avatar
didn't got the time to install it yet. I hopefully will do it soon and keep you update
Old Dec 23, 2013 | 10:35 AM
GregTR's Avatar
2014 E350 Wagon, 2025 GLC 350e, 2026 E53 Wagon
Here is the pre-facelift sedan install guide. The wagon is obviously slightly different as is the new facelifted model due to a new CAN bus.
Old Dec 23, 2013 | 04:33 PM
T.H.Carrera's Avatar
2012 w221
Can you pull the install guide for backup camera on a GLK?
Old Dec 23, 2013 | 08:58 PM
GregTR's Avatar
There is no official retrofit for rear camera for the GLK but there is a retrofit guide for the ultrasonic parking sensors. Also note that the guide I posted for the E-class specifically excludes North American vehicles too.
Old Dec 24, 2013 | 06:14 PM
2012 w221
thanks for the info
Old Dec 24, 2013 | 10:25 PM
leapingpoint's Avatar
E-class
you also need to decide where to put the camera. the original camera is mounted not in the center but at the right of the license plate light. most people who have installed this camera themselves have chosen the easier way - replacing the right of license plate light with the camera. personally i wouldn't do it that way coz at night your license plate would look funny (one side bright, the other dark).
i have some photos of this installation (also show where the wiring should connect in the back of COMAND APS), but it's on a different PC and i won't be able to access it for another 2 months. if you're not in a rush (sure seems you're not) i will post some photos later on.
Old Jan 9, 2014 | 07:36 AM
LuisGese's Avatar
Mercedes W164 320 Cdi 4Matic 224hp
I just bought the camera and the modulator for my W212 2010, can you the tell me the correct wiring to buy to my car?
Old Jan 9, 2014 | 09:42 AM
norwayw212's Avatar
c 238 220 diesel 4matic
camera A212 820 2797
wiers A212 4406834
modulator A212 8270006
MB montage anleitung - AN54.65-P-0030-03CW
TOO AN W212 - 2010
http://www.mercsworld.com/index.php/startseite.html
Old Jan 9, 2014 | 11:19 AM
LuisGese's Avatar
Thank You Norwayw212, just need to buy the cables now
Old Jan 9, 2014 | 11:24 AM
LuisGese's Avatar
Norway, you sell this material?
Old Jan 9, 2014 | 02:00 PM
norwayw212's Avatar
No dont sell - send Your request too http://www.mercsworld.com/index.php/startseite.html`
He is the big guy in MB parts in Germany . If any problem With writing german send me an e mail and i loock into it . Sitting my selv in Norway .
Old Mar 18, 2014 | 02:46 AM
2nice4me's Avatar
2011 E350 4 Matic
I changed my mind on the location of the camera and am ordering a new camera that I can place closer to the middle.
I need to order a new trunk lid handle (the black plastic that holds the 2 back up lights and trunk handle) does anybody know what the part number is (2011 W212 Sport).
Old Mar 18, 2014 | 11:52 AM
konigstiger's Avatar
'71 Pinto
2127400793 check your email
