BHP difference in 2012 vs 201[0,1]
So I've got a lease up on my current car in April and have been researching cars the past few months. I'm 90% sure I'm going with a w212.. it's a matter of just which one. The reason for this thread specifically is how noticeably different is the power in the 350 between 2011 and 2012. The 2012 goes up to 302 hp, however most of the stats I've been able to find online indicate no change in zero to 60 time, is this the case? Would a tune from oetuning (which pushes the NA 2011 motor to 284 hp) actually feel faster than the 2012?
The only thing that's pulling me away from picking the w212 is the power. I test drove a 2010 350 and while it wasn't a dog, it wasn't necessarily invigorating either. I could go for the 550 but in my price range I'd be looking at a 2010 550 and I'd like to have that extra year of warranty if possible. Aside from the fact that the airmatic suspension is a concern as far as long term maintenance costs.
Alternatively I've looked at 2011 535i's, 2012 xf's, and 2012 a6's (3.0) however each of those come with long term reliability concerns not present in the mb and the jag/audi price would have to come down a bit to be in my sweet spot.
Of course we're taking an I6 Turbo vs V6 so the overall feel is also pretty different. I think 535i 1/4 mile figures generally should be about a half second or so quicker than the new E350.
That said I found the new E350 plenty fast for me and of course being an MB the power delivery is smooth and all. It has some anger to it when you Punch it off the line.
The BMW has the same hp but more torque due to turbo fuel injection, making it a little faster o to 60. K-A says the Bimmer hp is underrated. That, simply is not true.
As far as the BMW335 being more like a V8, is also incorrect. I have a 2013 CLS 550 4.6l twin turbo V8 with 443 lbs of torque. It just blows the doors off the BMW 335.
You will not be disappointed with the E350 but if power is a big deal, wait a few months and order the 2014 E350. This is a face lifted model with a new twin turbo engine that develops 329hp and will leave the BMW in the dust.
As far as "feeling like a V8", you've said that before yourself, lol. Didn't your 3 Series have an N54? I'm not comparing it to a TT V8 like the CLS, I'm saying the down-low torque and grunt of the N55 feels more like a V8 than a V6 (it makes its peak torque at around 1,200 RPM's and holds it). In fact the motor is known to be stronger down low and if anything run out of breath at higher RPM's, which is VERY uncharacteristic of a BMW I6 engine, and more characteristic of a typical V8 motor.
I recently drove a brand new CLS550, and around town I didn't notice a big difference in torque than from my car. In fact, due to gearing more than anything I felt more usable torque at the pedal with the 535i as the CLS550 had more noticeable Turbo lag. It was when I punched it the CLS's power difference shined and the car pulled me back to my seat in a way my car certainly won't.
As for the facelift. The 329 HP in the E will probably have it putting out numbers similar to the 535i, with a slight edge due to less weight I'd assume. However the 329 HP from what I understand is not confirmed to be the E350 as it may have the exact same output and motor as the current years.
C&D tested a 2012 E350 Wagon 4Matic to a 14.6 @ 97 MPH. The Sedan should post probably a a MPH higher due to (maybe?) some weight savings.
C&D got a 2011 535i at a 14.2 @ 102 MPH.
The E350 makes its PEAK torque at of 273 lbs/ft at 3,500 RPMS. The 535i makes its PEAK torque of probably a realistic 330 lbs-ft (I've seen dyno's range from 280 to over 300 at the wheels) at a whopping 1200 RPM's and holds it. Hence why I said it "feels more like a V8".
The 2010-2011 E350 will make its peak torque of 258 lbs/ft at 2400 RPM's. Which gives it a nice smooth ride around town, IMO. Its 1/4 mile tests usually range around 14.9-15.0 at around 94-95 MPH (for the Sedan).
Hopefully those figures help you out, O/P. I'd recommend the 2012 E350 if you are in any way concerned about acceleration. Though I found my 2010/2011 E's more than capable around town, if performance is something you're seeking, you'll most certainly be happiest with the 2012+.
