E350 idle-- ??
my 2013 E350 gasser idled perfectly for 3500 miles. By that I mean the tach
stayed at same exact rpm at idle, be it fast idle at startup or slow idle when warmed.
Now it sometimes varies slightly, you can see the tach needle waivering 50
or 75 rpm's.
Probably most variance (but still occasional) when restarted after an hour or two of sitting.
Mostly it is fine but I'd like to solve this .
Anyone else have this or have any ideas?
It happened to start doing this after my first and only fill with Holiday Blue
Planet gasoline. I believe it has different formulation than others.
Coincidence?
thanks for any ideas.
When it does this, it feels like an injector or plug is misfiring...
No errors codes come up on dash.
From SeaFoam site:
"Moisture: Fuel can absorb moisture from the atmosphere and from condensation – even more so with the addition of ethanol. Sea Foam fully emulsifies the water in the fuel. Allowing the moisture to burn through the engine and be harmless."
If you think it is a problem then step away from the Seafoam and go to the dealer. Complain about a rough idle and see what they say.
Dubious self help methods seldom help during warranty and often lead to warranty claim denials down the road,
As for the fans running longer , I assume you leave your A/C on all the time , if this is the case , turn off the A/C before your turn off the car
or 75 rpm's.
Coincidence?
You live in an area where the summer comes a little bit later than where I am. Is it possible that this problem started when your warm weather came? With 3500 miles on the clock you bought the car 2 - 3 months ago when your summer was not at best yet?
The rpm fluctuation could be caused by the AC compressor kicking in and out. To verify this let it idle with AC OFF and see if it fixes it.
I've been doing bp gas since I noticed it, but before sometimes got it from speedway and Kroger. Always get the highest premium. Also the premium prices are getting further away from reg. Like it's over $80 for a fill up now.
