Sponsored by: CARiD
Dorky badge removal
Old Jul 5, 2013 | 02:50 PM
Bigglen1's Avatar
2012 E350 RWD, 2003 Aprilia RSV1000 Tuono
Dorky badge removal
Can this "Blue Efficiency" badge be removed w/o leaving a mark?
Old Jul 5, 2013 | 03:10 PM
sleewell's Avatar
2011 E350 4matic
im guessing yes, all the other badges come off real easily without leaving marks. looks much cooler imo
Old Jul 5, 2013 | 03:55 PM
ScottNJ's Avatar
2012 E350 Cabriolet 2013 BMW F10
Yes, very easily by easing dental floss and goo gone. At first I thought it would leave a hole behind like the three pointed star does, but it is held on by adhesive. I removed the blue efficiency badges along with the "E350" on the back.
Old Jul 5, 2013 | 09:01 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Sure. As long as the car is fairly new you shouldn't see any residual marks.
Old Jul 6, 2013 | 12:18 PM
greasykid's Avatar
2015, ML250 BlueTEC
B E Removal
Took mine off with my wife's hair drier. Just heat the badges and gently easy off. No marks at all.
Old Jul 6, 2013 | 12:29 PM
greasykid's Avatar
2015, ML250 BlueTEC
B E removal
Heat with hair drier. Mine came off easily.
Old Jul 6, 2013 | 02:29 PM
hyperion667's Avatar
2012 CLS63
awesome! badges be gone!!
Old Jul 10, 2013 | 07:21 PM
AnirInTexas's Avatar
2011 E-350 P2 Cuprite Brown/Chestnut
I also like the debagged car. I did mine and I am happy I did it.
Old Jul 17, 2013 | 10:52 PM
Bigglen1's Avatar
Thumbs up Follow up
RESULTS: DONE! Used a hair dryer, peeled those suckers right off. Then a little bug & tar remover and WD40 removed any residual adhesive. Then some spray polish and it looks good as new. In fact much BETTER than new. :-)
Thanks.
Old Jul 18, 2013 | 12:59 AM
Thanks.
Pictures?
Old Jul 18, 2013 | 07:49 PM
Bigglen1's Avatar
Originally Posted by AnirInTexas
Pictures?
Well there's really nothing to take a picture of. The badge is gone. lol
Look at the pic in the original post. Now, imagine the badge gone. Now you "get the picture"?
Old Jul 20, 2013 | 10:10 AM
Pmurray633's Avatar
2018 CLS550
I have a 2011 e550. If I pull the badging off, think there will be some paint fade makes? Mine is black.
Old Jul 20, 2013 | 10:28 AM
ScottNJ's Avatar
There may be some slight fade, it really depends on how long your car has sat in direct sunlight, if it is garage kept then you should be fine. I know when I debadged mine there was slight fading for the first day but after really wiping it down it is gone and looks flawless. It's worth a shot, the badges can always go back on if you need to.
Old Jul 20, 2013 | 10:30 AM
2012 CLS63
I had mine taken off, it's also an 11 550, and there were, and still are shadow marks that you can see......it's a bit worse when the sun hits it just right, but it doesn't bother me because I'm selling/trading it soon anyway....
I wish the dumbo factory would release cars with no badge......like all the other car makers
I'm thinking it will show, depending on how you address the left over glue..
good luck!
Old Jul 20, 2013 | 10:31 AM
Pmurray633's Avatar
2018 CLS550
Thanks Scott! I think I will give it a try!
Old Jul 20, 2013 | 11:40 AM
CEB's Avatar
CEB
good luck!
Your paint has faded over the years and your exposed paint (i.e. the paint not under the badge) will have swirls while the paint under the badges will be pristine.
The only way to reduce the difference is to properly detail the rest of the car.
