Sponsored by: CARiD
Banged up wheel...replace or anyway to fix?
Old Sep 3, 2013 | 12:54 PM
xolinlevh's Avatar
2011 E550 4Matic
Hey guys. So i moved to a new house a couple weeks ago, and the curbs are a couple inches higher then I'm used to....so while parking the other day i banged up the wheel rather bad hitting the curb. In addition to some scrapes on my rim i looked and saw a nice chunk of the tire itself is ripped back. At first i thought it would be an instant flat but pressures held mostly for the last few days. This morning tho i got the low pressure warning, but its still upper 20s (27/28) which is low...but not flat. I had been planning on buying a set of winter tires end of this season so ideally don't want to have to shell out for a new set of summer/all seasons for only a couple months use before then getting winters. I'm curious if anyone knows of a way to maybe patch this up? My thought had been to just pour super glue in it and see how that goes....
PS sorry for the poor pics, i can retake more later
Attached Thumbnails Banged up wheel...replace or anyway to fix?-photo-1.jpg   Banged up wheel...replace or anyway to fix?-photo-2.jpg
Old Sep 3, 2013 | 02:04 PM
stale-bread's Avatar
2010 E550
Super glue?? This can be a huge safety issue to you and your passengers. Your sidewall could easily blow out at high speeds. I would replace it asap.
Here is a link that says it "may" be possible with the right tire shop.
http://http://www.carsdirect.com/car...-repair-basics
I do understand not wanting to replace all 4, but why not just this one?
Old Sep 3, 2013 | 02:18 PM
hyperion667's Avatar
2012 CLS63
ouch, that stinks.....
I agree with -bread, get a replacement, maybe find a used in that size
to help hold you over until the new tire season.....
if it were up a bit higher on the sidewall you might be able to slide by.....
but that's a bad spot.....surprised it's holding the air for you....
good luck and congrats on the new diggs
Old Sep 3, 2013 | 02:31 PM
xolinlevh's Avatar
2011 E550 4Matic
Thanks for the replies guys...I figured id prob be out of luck, amazed it didnt go flat right away ands been holding air for 3-4 days now like this. I'll start lookin for tires!
Old Sep 3, 2013 | 02:40 PM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
Look quickly, because that tire is an accident waiting to happen. Whenever you have damage like this, you are open to a catastrophic tire failure where that area fails immediately.
Old Sep 3, 2013 | 10:27 PM
xolinlevh's Avatar
2011 E550 4Matic
Can anyone confirm quick if these would work? my options are $1100 from dealer, $750 from tirerack, or those......Or alternatively just buying 2 for the front and halving the cost, buying a winter set in a couple months, then the final 2 next spring.....
oops *edit* just noticed those are 235/255 staggered set. I need 4x 245/40R18, right?
Old Sep 3, 2013 | 11:58 PM
Arrie's Avatar
Well, it can look bad but always is not.
I had an incident where I drove over a metal bar on the interstate highway at 70 mph speed. Could not avoid hitting it as it was right across the lane and other cars next to me. Saw it too late to stop. I almost got away with it but hit the end of the bar, which made a nasty cut on the side wall of the driver side rear tire. The cut was about 1 1/2" wide and about 1" long. It was like you would have cut it with a sharp knife trying to cut the rubber away from the structure.
I stopped at the first tire service place I could find wanting to buy a new tire for it. For a big surprise after the tire guy looked at it he said that certainly he can sell me a new tire but a $3 super glue will do just fine.
He said that if the cut does not expose any reinforcement inside the side wall you have not compromised the tire and just gluing the "flap" with super glue will do just fine.
As I had expressed my desire to buy a new tire and then the guy tells me I don't need to I believed him. I bought a tube of super glue and glued the flap back down. Never had a problem, never leaked air. Drove the tire another 10 000 miles when it was time to change for wear.
Old Sep 4, 2013 | 07:24 AM
2012 CLS63
yes, that is the tire/wheel size.......have it on my '11 as well.....
so you can't find one used to get you buy?
guess it might be tough to find just one eh?
if you're going to buy new ones soon anyway, I'd try to get just one to save money
Old Sep 4, 2013 | 11:08 AM
xolinlevh's Avatar
2011 E550 4Matic
Thats what i really want to do....theres maybe a minor leak in the tire, but my thought was the glue would hold it....but its prob better not to take a risk given that it IS leaking (albeit slowly...)
Ive looked around online, craigs, ebay, etc, no stores locally even source them. If it was possible id buy a single used one to replace the damaged one....but havent had any luck finding any.
Old Sep 4, 2013 | 02:39 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
If you don't need the same make/model tire, how about something like this http://www.ebay.com/itm/ONE-NICE-PIRELLI-P-ZERO-ROSSO-245-40-18-P245-40R18-245-40-18-TIRE-22161-Q-/300949566558?pt=Motors_Car_Truck_Tires&hash=item4611fdf45e&vxp=mtr
$57 for a used tire in 245/40/18
If its temporary it should be ok.
Old Sep 4, 2013 | 04:04 PM
xolinlevh's Avatar
2011 E550 4Matic
Just set up an appt for friday to get 2 new ones put on the front ($560). Could be worse!
Old Sep 4, 2013 | 04:05 PM
xolinlevh's Avatar
2011 E550 4Matic
Originally Posted by thenew3
If you don't need the same make/model tire, how about something like this Here
As nice as that cheap is....id be worried mixing and matching tires, diff model, diff wear. And MN roads are bad enough as it is without un-even grip
Old Sep 4, 2013 | 04:45 PM
Arrie's Avatar
Sorry this probably too late.
I have a used Pzero Nero 245/40-18 with about 4/32" wear left. This is to that cross bar at the bottom of the grooves, i.e. The height of that bar is in addition to this.
Long time ago i posted that i will give it away but nobody has asked for it.
I still have it and it is yours if you want it. Just pay shipment.
You said you set up appointment to replace fronts so perhaps you can't cancel it?
Old Sep 5, 2013 | 11:26 AM
xolinlevh's Avatar
2011 E550 4Matic
Hey, where are you located? How quickly/how much is shipping to get it to MN? Zip 55105. I believe can cancel no problem as i didnt give them my card # or anything..... Would save me a ton of $$$....
Old Sep 6, 2013 | 11:24 PM
brauhaus313's Avatar
asdas
Old Sep 7, 2013 | 12:06 AM
Arrie's Avatar
Originally Posted by brauhaus313
My tire is now on FedEx hands to be delivered up north. Happy to be helping a fellow MB driver.
I lost one on front for a side wall puncture and I did not have time to wait for a P zero Nero that my local guy would have to order. So I went with the Firestone they had as next day. Wide Ovals (have them in rear too now) have been better than the P zeros but I know about some better tires I will get next time.
I know the pain of spending money for a stupid one tire failing that requires buying both on the axle...
Old Sep 7, 2013 | 06:41 AM
2012 CLS63
respect to Arrie
