Sponsored by: CARiD
Battery Light Came on Navigation off
Old Sep 14, 2013 | 11:16 PM
faz999's Avatar
E350 -2012 W212 4 Matic
Hi i was driving and my Battery light came on orange ?
car is 2012 19k miles what does that mean ?
new battery ?
I went home turn the engine off then 5 minutes later turned it on no warning battery light and navigation was working.
Do i need a new battery or what ?
thanks
Old Sep 15, 2013 | 10:37 AM
Arrie's Avatar
new battery ?
thanks
That battery light is probably indication of alternator failure. You may have alternator going bad.
I don't know if the car saves a trouble code for an issue like this. If the light is out when you take it to the dealer they won't be able to do anything unless there is a code for it.
Or perhaps they could run an alternator load test?
Old Sep 15, 2013 | 11:29 AM
petee1997's Avatar
...24 GLE53
This is a wild guess but could it be the warning to replace your key battery. I am assuming you keyless entry.
Old Sep 15, 2013 | 02:27 PM
faz999's Avatar
Thanks for the reply. Yes every time I turn off the car battery indicator light go off I will have to keep the engine running so the light stay on.
Twice it had happened will call dealership to schedule check up under warranty
No this is not a keyless entry
Thanks again
Old Sep 17, 2013 | 04:04 PM
faz999's Avatar
Just got back from the dealership checked everything told me nothing wrong but my light shows up once a day and command turns off after battery red light warning shows up.
Anyone had similar issues ? or any idea what can be going on.
TIA
Old Sep 17, 2013 | 04:28 PM
MDMercedesGuy's Avatar
2024 GLS450
Best advice:
Take video with your phone next time it happens. Clearly state in the video the date and time, and what you were doing when it happened. Demonstrate how you can "fix" the issue if you can with a restart.
Make sure to upload it to youtube so that it can be accessed by a tech at the dealer.
We were chasing down an intermittent issue with my backup camera (ended up being a loose pin in a connector in the wiring harness in my trunklid) - and the video was the only way I could prove it happening/the only real way they could diagnose the issue.
Old Sep 17, 2013 | 04:33 PM
faz999's Avatar
It just happens randomly, I can be driving and then the light pops up it going to be tough to take a video while it pops up when i am driving.
But i will take a video will show red battery warning light and central command turns off.
As soon as i turn off and start again i am good for rest of the day..
I can see this is going to become a nightmare to diagnose...
Old Sep 18, 2013 | 01:50 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
If the warning light is being triggered, there has to be a corresponding code being generated. I would go to a different service establishment and have them read the code when the light is triggered. Then return to your MB dealership.
