Sponsored by: CARiD
Trying to figure out my wheel & tire situation
Old Dec 30, 2013 | 12:39 AM
tunerm's Avatar
W212 E 350 4Matic
Hello everyone,
I have a 2010 E350 4matic. I have just lowered it 40mm with Vogtland springs. Im trying to figure out my wheel situation. I have 20 x 9 35 offset all around. I test fitted the front wheel and it is poking out, the rear is not a problem. There is about an inch of space between the wheel and the strut assembly. I didn't think it would stick out this far, with it fully lowered the wheel protrudes about 8 to 5mm dependent on where you look from. I am thinking of either having the wheels milled down on the back pad 3 - 5mm(looks sketchy) or send them back for 40 offset but I'm not convinced it will fit without any rubbing issues. I use this car as my commuter and i drive about 180miles a day so i don't want to much hassle when it comes to the aggressive stance wheels. I also went with a square setup so i could rotate the wheels.
From most of the searches I've done here most are running 20 x 8.5 38 to 40 offset with w 235/35 20 or 245/30 20. Do you think I will definitely rub with a 20 x 9 40 with a 235/35 20 up front? Im hoping someone with a 9inch front can shed some light on this, offset used and how much space they have to the fender.
Im at the point where I'm going to just get another set of wheels.
I attached some pics of what i have.
Attached Thumbnails Trying to figure out my wheel & tire situation-photo-1.jpg   Trying to figure out my wheel & tire situation-photo-4.jpg   Trying to figure out my wheel & tire situation-photo-2.jpg   Trying to figure out my wheel & tire situation-photo-3.jpg
Old Dec 31, 2013 | 11:50 AM
tunerm's Avatar
W212 E 350 4Matic
Wow surprised no one responded. Just an update rotiform confirmed that 4mm can be shaved off backpad. I then confirmed also from a local wheel machining company that 4mm is capable. There is a requirement by law which I found is there is a min of 8mm between backpad and bolt perch.
Originally Posted by tunerm
Hello everyone,
Old Mar 24, 2014 | 12:42 AM
ttsagris's Avatar
E350, Z-06, 330xi, Highlander
I just bought a CPO 2010 4matic, so I'm looking for mod ideas. Your car lowered on the stock alloys...... epic.
Old Mar 24, 2014 | 09:04 PM
BozzMazzi's Avatar
2012 S550 4M Diamond White. 2012 E350 4M Matte Blue, 2013 C300 4M White
Hello everyone,
Now I'm nervous, I was advised to go with 20x9 38 (flush with fender) and run 225/35/20 because I wanted to also lower my 2012 E350 4M. Unfortunately, I don't have them installed yet but should be done some time this week.
Old Mar 26, 2014 | 02:36 PM
juliana21's Avatar
13 E350 4MATIC
Relax, nothing to be nervous about. You did a search and found the information
Ur looking for but second guessed it. You even said everybody is running 235/35 but decided to do 225
20 x 9 et38 235/35 20
20 x 10 et40 275/30 20
Lowered 1.5in - Flush Fitment, No Rubbing
2013 E350 4matic
Old Mar 27, 2014 | 11:04 PM
tunerm's Avatar
W212 E 350 4Matic
I agree. After cutting my wheels to 39 offset. And running a 235/35R20. No problems no rubbing at all.
Old Mar 28, 2014 | 08:07 AM
hyperion667's Avatar
2012 CLS63
cutting your wheels??
Old Mar 28, 2014 | 09:18 AM
tunerm's Avatar
W212 E 350 4Matic
I had the backpad shaved from a 35 offset to a 39 offset.
Old Mar 28, 2014 | 11:49 PM
juliana21's Avatar
13 E350 4MATIC
Any more pics?
Old Mar 28, 2014 | 11:51 PM
tunerm's Avatar
W212 E 350 4Matic
Originally Posted by juliana21
Any more pics?
Just this one.
Attached Thumbnails Trying to figure out my wheel & tire situation-image-2959332050.jpg
Old Mar 28, 2014 | 11:55 PM
BozzMazzi's Avatar
Just this one.
looks good
Old Mar 29, 2014 | 01:55 AM
tunerm's Avatar
W212 E 350 4Matic
Originally Posted by BozzMazzi
looks good
Thanks Bozz
Old Mar 30, 2014 | 02:46 PM
bob2011's Avatar
2011 E550
Your car is SEXY!
Old Mar 30, 2014 | 02:55 PM
tunerm's Avatar
W212 E 350 4Matic
Originally Posted by bob2011
Your car is SEXY!
Thanks bob
Old Mar 30, 2014 | 07:17 PM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
I think it looks great, the 40mm looks like a perfect drop!!
Old Apr 2, 2014 | 12:33 AM
juliana21's Avatar
13 E350 4MATIC
Car looks perfect!!
Old Apr 2, 2014 | 03:23 AM
D&G's Avatar
D&G
W212 E550
Personally I think 20x9 35et sits perfectly flush up front. I wouldn't go any higher in et. And once dropped the camber will go negative giving more spacing between the wheel and front fenders. Did you rub with 20x9 35et? Is that why you want to shave off the et.
