Engine On/Off
I haven't had time yet to go through the manual or spend time with the car so I'm not yet familiar with everything this car has - in fact, at this point I'm not really sure if this is a feature or an issue. What do you all think about this feature? Can this be turned off? If so, do most of you leave it on or off? I'm not liking it too much and I'm also concerned that by switching on & off so many times, something can go bad quickly. Is this only available on 2014 models or earlier ones as well?
Having driven other cars with this feature, a Euro spec VW Touareg TDI, I must say that the ECO Start/Stop in the E-class is one of the best behaving and least intrusive ECO system there is. I have no problems with it and I'll keep it on.
Hopefully this doesn't take a toll on any engine part. There is a lot of stop & go traffic in my area especially during the rush hour commute and I would hate to have anything fail prematurely because of this.
Apparently, the system remembers which cylinder should fire next and the restart is done by firing that cylinder which spins the engine. Clever....and with no obvious areas for excess wear if you keep your oil clean.
I am starting to get used to it. Where I don't like it yet is when I am waiting to turn right at a red light. When you creep forward, it starts and shuts down right away. I just flip to S mode and that turns it off.
When you turn ECO ON and start-stop is in action then the car will start you off in 1st gear. It's actually easier to leap off the line with ECO on.
Apparently, the system remembers which cylinder should fire next and the restart is done by firing that cylinder which spins the engine. Clever....and with no obvious areas for excess wear if you keep your oil clean.I am starting to get used to it. Where I don't like it yet is when I am waiting to turn right at a red light. When you creep forward, it starts and shuts down right away. I just flip to S mode and that turns it off.
"How the ECO start/stop system works in detail: as a general principle, the engine is switched off every time the vehicle comes to a standstill (auto-stop function. Restarting the engine (auto-starting function) takes place almost imperceptibly; and moving off without any noticeable time lag compared to a stationary vehicle with its engine running. This rapid action is attributable to two special features: a crankshaft Hall sensor which is able to identify the rotational direction of the crankshaft enables the engine control unit to identify the cylinder in which the piston is ideally positioned for starting. The fuel is injected into this cylinder first, thereby speeding up the starting process. An additional electric transmission oil pump supplies the clutches of the automatic transmission with oil pressure prior to starting, so as to enable a swift resumption of the journey after direct starting of the combustion engine via the ECO start/stop function. The starter motor (starter) has also undergone thorough modification: it is now designed to cope with eight times as many starting procedures, ensuring that it will last a car's lifetime in continuous urban driving involving frequent auto-starting. In addition, the on-board electrical system is supported by a second battery."
There is a starter motor as well as a second battery involved in the system.
Its funny how last night I thought there was an issue with the car and was about to return home to take our other car.
