W212 Tail light problem
Old 01-13-2014, 10:50 AM
Las84's Avatar
W212
Hello, I have a problem with my W212 E-class.
The right side LED tail is always on after shut down. Just the one side and 4 LED is on always after yesterday.
Its one LED in either side of the corners on the inner light/lamp on trunk.
Anybody who have had this problem? Easy fix?
Searched the forum in forehand with no resuts.
The car is an Europen model and its not the light for smal streets function, becouse its only in the back. Hope someone can help.
Sorry for any bad languge.
Old 01-13-2014, 11:33 AM
Tjdehya's Avatar
2023 EQS 580
Turn off your parking lights?
Old 01-13-2014, 11:37 AM
Las84's Avatar
W212
They are off. Switch is at auto.
Have taken off the negative for a "cold start" of the ecu, but no luck there either. Know it was a long shot but one could be suprised.
Old 01-13-2014, 01:39 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Rear fog light?
Old 01-13-2014, 02:59 PM
Las84's Avatar
W212
My first guess but the wrong side. Mine has only fog on left side.
Old 01-13-2014, 03:24 PM
Tjdehya's Avatar
2023 EQS 580
If its not your fog lights or parking lights then it sounds like a short.
Old 01-13-2014, 03:31 PM
Las84's Avatar
W212
That I was afraid of. Damn. Could it be in the SAM module? Or a fuse somewhere?
Thanks for the replies by the way.
Old 01-15-2014, 07:25 AM
samcold's Avatar
E250 W212
Hi,
I've got the same problem today...my E250 W212 rear light does not went off automatically...even the licence plate still switch on after locking the car...
does anybody have this issue??? or fix?? is this known issue for this model?
Rgds
Sam
Old 01-16-2014, 06:13 AM
Las84's Avatar
W212
Sent PM
Old 01-24-2014, 05:00 AM
Las84's Avatar
W212
Sorry for not uppdating. Been away on a little holiday.
Found out it was the rear SAM module that was broken. A new one was ordered and mounted. Problem solved under Waranty.
Old 01-24-2014, 05:21 AM
BenzV12's Avatar
W212 FL
That's good , I was not aware of such a failure or SAM module can fail . Thanks for your update
Quick Reply: W212 Tail light problem
