Sponsored by: CARiD
Synching Phone Contacts (iPhone)
Old Feb 27, 2014 | 08:52 PM
shashivr4's Avatar
2013 E350 Sport Wagon - 4Matic
When I attempt to synch the contacts off my iPhone (5) to my 2103 E Class, the end result states "0 contacts received" on the Comand screen.
Any ideas on what I may be doing wrong? I'm connected via BT when attempting the synching.
Would appreciate any help. Thanks!
Old Feb 27, 2014 | 09:02 PM
LasVegasMike's Avatar
2011 E350 Sedan
Does the car use the phone normally otherwise? As in can you make calls?
Do you have your contact on some custom contact list on your phone? If you go to Phone > Contacts > Groups are all the lists checked?
Old Feb 27, 2014 | 09:06 PM
shashivr4's Avatar
Yes, I am able to make and receive calls via BT.
My contacts are not on a custom contact list. After "phone," I don't have a "contacts" option.
Old Feb 27, 2014 | 09:14 PM
2011 E350 Sedan
When you touch the phone app icon, that open the phone app on the phone. Along the bottom you should see favorites, Recents, Contacts, Keypad, and Voicemail. That's where you can see contacts.
There is also a contacts icon on one of the screens.
Old Feb 27, 2014 | 09:21 PM
shashivr4's Avatar
No "groups" under contacts. In any event, I've never set-up any custom groups. Anything else I should try/check? Thanks.
Old Feb 27, 2014 | 09:29 PM
2011 E350 Sedan
Check the next option:
Settings > Bluetooth > Tap the blue 'i' next to the MB Bluetooth listing
On the next screen make sure 'Sync Contacts' is enabled
Old Feb 27, 2014 | 09:38 PM
shashivr4's Avatar
It is.
Old Feb 27, 2014 | 09:40 PM
2011 E350 Sedan
I don't have any other recommendations other then deleting the phone from the car, resetting the phone, then connect it to the car again.
Old Feb 27, 2014 | 09:44 PM
shashivr4's Avatar
Ok...thanks again for your help. I'll try that tomm.
Old Feb 27, 2014 | 10:49 PM
drsaab's Avatar
Did you go to the bottom left of the phone menu to download contacts?
Old Feb 28, 2014 | 09:26 AM
shashivr4's Avatar
Attachment 280291
Yes, I did. I chose to import contacts from phone (forget exact wording). The Comand system looked like it was processing information but the output I received was "0 Contacts Received."
Old Feb 28, 2014 | 10:08 AM
2011 E350 Sedan
I'd stop by the dealer and ask them. At the MB dealer I went too they have the younger porters trained on all the electronic stuff so they just jump in the car and help out real quick without tiring up a service adviser. Maybe they can take a quick look for you.
Old Feb 28, 2014 | 07:00 PM
shashivr4's Avatar
So I attempted to synch the contacts off my iPhone again today. Once again, the message I received was "0 contacts received." However, after looking closely, I discovered that the contacts were indeed transfered to Comand. I tested it by triggering a call by using the voice regonition capabilities. It worked! Thanks again for everyone's help. It is much appreciated.
Old Feb 28, 2014 | 10:57 PM
2nice4me's Avatar
2011 E350 4 Matic
How many contacts can the command store? i am able to transfer but it will stop almost at the end and display that there isnt enough memory?
Old Feb 28, 2014 | 11:33 PM
2011 E350 Sedan
I had the same issue, but in my case it was trying to transfer 5,000 contacts! About 4,900 of them were simple email addresses that Outlook had added to my phones main contact list. I downloaded an app that searches contacts and then allows you to do a mass delete based on contacts that have no numbers, or if they have just an email, or no names etc. The app was called MultiDelete.
After that it synced fine, but I have no clue what the limit is.
Old Feb 28, 2014 | 11:41 PM
2nice4me's Avatar
2011 E350 4 Matic
Thanks, will give that a shot
