What premium fuel to use?
I contacted the dealer who advised me to use "Shell" premium gas. As soon as I did that, my fuel economy read 22mpg. What a difference between the premium fuels??? I'm amazed.
I have learned that in many name brand gas stations including all of them gas can be really low quality and for sure not at the octane rating it says on the pump. For some reason every time I fill up at a Citgo station my gas mileage is the best.
Where is this Shell that has non-alcohol blended premium gas?
I use whatever 93 octane (91 is very rare in NYC area) is the cheapest with a credit card (some jokers charge a $0.10 swing on credit card purchases). I've been buying 93 octane BP gas in Yonkers, NY for 3.939 for the past few weeks. 93 in CT near me is 4.259 up to about 4.909.
The 'Additives in gasoline' section goes on to say:
"One of the main problems of poor fuel quality is the forming of deposits that are caused during the gasoline combustion process. Mercedes-Benz recommends that you use fuel brands that have the additives. If you use fuels without these additives for an extended period of time, there may be a buildup of carbon deposits, especially on the inlet valves and in the combustion chamber."
So I always use Top Tier Gasoline (http://www.toptiergas.com/index.html) retailers.
Has any member on this forum experienced any issues using it?
Is it safe to use on a new e 350?
Now at my local Costco they are adding a additive called "Clean Power" at many of their stations. More details at http://www.costco.com/gasoline.html
I do add a bottle of Chevron Techron injector cleaner about twice per year and this is actually recommended by MB. Some dealers do it as part of their service.
If you don't want ethanol, contact your US House and Senate legislators. However, you are fighting a hugely profitable coalition of agri-business, transportation and distributors.
All gas sold in US has at least 10% ethanol, no matter the grade. You can find non-ethanol gas at some independent stations, but it usually costs quite a bit more. Then again, it is also from independent stations.
The very powerful ethanol industry is pushing hard for all stations to primarily sell 15% ethanol. Unless Congress stops it, they will succeed.
I spoke with the manager of a distribution center I know. Most people refer to these as "tank farms" that are located along the pipelines. The fuels that go into the trucks are primarily differentiated by the additives that are added to each truck before it leaves the tank farm.
This is a problem that creeps up on you. With cheap gas you can start having rough starting idles at 15k miles.
Of course, who knows what the base gasoline is when it comes out of the pipeline and what additives the distributors add or subtract periodically.
click on your state and you should find outlets for non-ethanol.
I have never read anything definitive on this topic but there has been enough chatter about the impact of ethanol on various fuel system components that I use nothing but non-ethanol. Don't forget that E350 W212 cars with the M278 engine are direct injection and use those extremely expensive piezoelectric injectors. I sure do not want those babies to get fouled by ethanol or other junk in the fuel. That Chevron fuel additive is also a good idea.
