Sponsored by: CARiD
Paint/coating peeling interior console
Old Jun 8, 2014 | 07:34 PM
jjack100's Avatar
2013 E350 4MATIC
I have a 2013 E350. The paint/coating on my center armrest/console is bubbling and peeling off. It looks to be coated plastic. I have attached a photo. Anyway, given that this car is only 1.5 years old, I'm wondering if this is something that would typically be under warranty -- and regardless of that, if this can be fixed/replaced.
Thanks, Jack
Attached Thumbnails Paint/coating peeling interior console-car3.jpg
Old Jun 8, 2014 | 08:02 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Had the same problem on my used 2011. See the pic I posted here. Carmax covered it under their warranty for me. Dealer also told me it would have been under warranty if I hadn't been over miles.
Old Jun 8, 2014 | 09:01 PM
PeterUbers's Avatar
Of course it would be covered under warranty -- it's not like you took a razor and did that yourself -- it's a defect in manufacturing of that part.
Get yer stealership on board and get it replaced, sorry that happened... so annoying this type of problem because now they have to tear up the center console and put it back together
Old Jun 8, 2014 | 10:35 PM
jjack100's Avatar
2013 E350 4MATIC
Thanks for the replies. I contacted the dealership (with photos) and was told that the service manager needs to inspect it in person to "determine the cause." Not exactly the response I was looking for. I guess we'll see how much of hassle this is going to be. I do not ride around with buckets of paint thinner so I'm not sure how they are thinking they might have some sort of out..if that is what they are thinking.
Old Jun 9, 2014 | 04:57 AM
alanme123's Avatar
2012 E350
I have the sports steering wheel and some of the silver paint is actually peeling off.. Wonder if this is under warranty as well...
Old Jun 9, 2014 | 11:14 AM
jjack100's Avatar
2013 E350 4MATIC
I don't see how paint peeling off on the interior can be normal wear after only a few years, even on the steering wheel. And even though this seems minor, it WILL affect the value of the car when you try to sell it. I find it kind of baffling that they don't use black plastic and instead use clear plastic with some sort of colored coating that will eventually come off and cause issues.
Old Jun 9, 2014 | 11:59 AM
PeterUbers's Avatar
If they give you a hard time -- call MBUSA and file a complaint and let them negotiate with the stealership -- this car is only a year old!!! C'mon
Old Jun 9, 2014 | 03:23 PM
thefisch's Avatar
Top Answer: 1
I think the bubbling up gives it away that the material or application of it is defective. Their policies probably make them diagnose in person just in case. Maybe they just want to be sure that it doesn't look deliberately cut or gouged from abuse which would have left damage to the underlying plastic. I wouldn't be worried. But yes their response is annoying.
Sorry that this happened to you, but now I am glad I am not the only one who had this problem. Let us know how it turns out.
Old Jun 9, 2014 | 10:41 PM
SLpat's Avatar
2011 E550
I think this is standard procedure. When I wanted to get the trim replaced due to fading it was the same. You have to go in, they write up the service order and then have the tech verify it is faded. Then they ordered the replacement kit. A lot of effort but if you work through the system it usually works.
Old Jun 9, 2014 | 10:43 PM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
I had the same in my 2010. Replaced under warranty.
Old Jun 10, 2014 | 12:07 AM
stale-bread's Avatar
2010 E550
Should be covered under warranty. Looks like the damage was caused by acrylic nails. Wife, GF, or Mistress perhaps?
Old Jun 10, 2014 | 05:20 PM
jjack100's Avatar
2013 E350 4MATIC
Update: the dealer is going to cover this. They ordered the part and are replacing it in a few days. I did have to push it a little bit, but nothing major.
Women and children are relegated to the backseat where they can do minimal damage, so it wasn't that.
Old Jun 10, 2014 | 05:48 PM
thefisch's Avatar
Top Answer: 1
Glad to hear they will address it. IIRC, it was a $100 estimate to replace at the dealer - ~$40 for part and rest for labor.
Old Jun 11, 2014 | 07:25 AM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
This not as clear cut as you might imagine.
This type of bubbling is often caused by oils (sunscreen, makeup, evil Armorall and the like) that finds its way under the paint under a minor scratch (caused perhaps, like a previous poster said, by a mistress in the throes of passion) and is technically not a manufacturing defect.
MB issued a bulletin a few years back about denying warranty coverage on similar issues caused by those vent clip-on air fresheners.
The good news is that most manufacturers will cover this type of damage as goodwill but it really isn't their fault.
Old Jun 11, 2014 | 11:42 AM
kash2014's Avatar
'10 W212 4matic P2-Distronic / '14 Cayenne / '04 X5 3.0 / '13 Altima
Still not as bad as BMW, I haven't seen one used beamer without the plastic rubbing off the steering and radio knobs, window buttons etc
Old Jun 11, 2014 | 12:03 PM
thefisch's Avatar
Top Answer: 1
I understand that abuse from passion or other causes shouldn't be covered. Perhaps the material is not defective, but they should really use a more durable material then or require wearing gloves as part of the warranty. Sunscreen, makeup, Armorall are normal, everyday products - not for me just to be clear
I understand the difference with the vents and the clip-on fresheners as the vents were not designed for that. However, if MB can't produce cars that don't have a musty AC smell, then they should consider a dedicated spot for clip-on fresheners.
Old Jun 11, 2014 | 03:33 PM
jjack100's Avatar
2013 E350 4MATIC
I agree that if you damage your car, it should not be covered under warranty. In this case, however, I did nothing that would cause this. There is no eating or drinking or suntanning or Armor-alling going on in my car. My guess is that this was caused by heat. I still don't see why they don't use a solid piece of black plastic as opposed to a coating that can come off. The dime they saved on that just flew out the window.
Old Jun 11, 2014 | 07:42 PM
v12driven's Avatar
SLC43,E500
Smile
Originally Posted by thefisch
I understand that abuse from passion .....
Is there something unique at work here? This appears to be a growing concern.
