Sponsored by: CARiD
Pano roof reopening by itself after closing
Old Sep 8, 2014 | 10:58 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Question Pano roof reopening by itself after closing
This is my 3rd MB & I had this issue with every single one of them
(2007 C, 2011 E Coupe, 2014 E Sedan):
(only) on hot days when I close the roof it sometimes opens (half) again by itself. Usually on the 2nd try it stays closed, though sometimes it takes
up to 3 tries.
but of course it never happened when the car was at the dealer,
so they never knew WHAT to fix..
and it seems I'm the only client with this problem.. on all THREE cars
Anyone else out there with similar issues that knows of a fix...?
Old Sep 8, 2014 | 11:14 AM
pamiboy's Avatar
E 350
Do you drive often with sunroof open? Is there any thing such as dirt or small objects in the path of the glass mechanism? I assume you have already checked those.
Old Sep 8, 2014 | 01:28 PM
Arrie's Avatar
up to 3 tries.
Have you tried to reset it? Hold the close button for a few seconds after it is full closed.
Old Sep 8, 2014 | 03:42 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I have had a similar issue on my pano roof but only when it was really hot. I figured it was due to the heat and the rubber around the wind deflector being tacky causing the roof to sense resistance to the point where it thought there was an obstruction. Each time it happened I was able to close it by holding the button. I'm thinking that maybe some lubrication on the rubber may solve the issue.
Old Sep 9, 2014 | 04:56 AM
Egonvdv's Avatar
thanks for the input guys, but all those suggestions have been covered indeed.
All my cars had the problem from the very beginning, when they were brand new.
Surely MB must know about this issue? I mean; 3 new cars since 2007, all with same problem.. strange.
Old Sep 10, 2014 | 09:13 AM
jmikolich's Avatar
2010 E350 4Matic
I've had this issue precisely 3 times on the same day and never an issue since. I attributed it to heat and expansion of materials adding some resistance.
What are you using to lubricate the slides? seals?
Old Sep 10, 2014 | 10:30 AM
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Try some 303 protectant on the seals. Has this issue one time on my 2010 E, and applied 303 over a year ago, and no issues since.
Old Sep 11, 2014 | 04:06 AM
Egonvdv's Avatar
the dealer did it, so no idea what product they used? (butter probably, as it never worked...)
I'll try the 303 protectant, just need to find it here in France 1st.
Cheers
Egon
Old Jun 8, 2015 | 05:14 AM
Egonvdv's Avatar
Well summer is back & so are my roof problems. Incredible...
Old Jun 8, 2015 | 08:50 AM
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
Do our cars have some sort of auto-open mechanism when the inside of the car gets too hot? I remember reading about a remote control feature that opened the windows and the sunroof when you hold down the unlock button. Could it be related to this 'feature'?
Old Jun 11, 2015 | 04:15 AM
iGeorge's Avatar
'12 E550 4M, '14 ML5504M
And it's not the system where it reopens because it thinks there is an obstruction?
