Sponsored by: CARiD
Headlights Manual Adjustment
Old Sep 19, 2014 | 07:55 AM
markmwenje's Avatar
w 212
Hi guys. I managed to find out how to manually adjust the headlights separately. However, I can only adjust for the dipped beam and not the high beam. can anyone advise how to manually adjust the high beam?
Old Sep 19, 2014 | 10:00 AM
CEB's Avatar
CEB
1953 300 Adenauer, 1971 300 SEL 6.3, 1975 600, 1978 450 6.9
You cannot adjust the beams separately. In the US and Canada, national laws forbid that. The same holds true for most European countries.
Old Sep 20, 2014 | 05:51 AM
markmwenje's Avatar
w 212
well mine is and its an Ex-UK w212. So surely there must be a way to adjust the high beam. anyone please help? Ive found another white like hexagon but it seems not to make a change when I adjust the same.
Old Sep 20, 2014 | 10:10 PM
ph350's Avatar
e350
Did you switch from the euro beam to US beam if you are in the states? I thought that would help more for your low beams. High beams just flood up so you don't really need to adjust those because they adjust with the low beams.
Old Sep 21, 2014 | 09:16 PM
CEB's Avatar
CEB
The hi/lo beam adjustment is pre-set at the factory and the adjustment screws are sealed so that they cannot be easily adjusted.
Old Sep 21, 2014 | 10:03 PM
pamiboy's Avatar
E 350
Would you care to tell us how can you adjust the beams, in case someone needs to do this (not me).
Old Sep 23, 2014 | 07:32 AM
markmwenje's Avatar
w 212
At the top of the light there is a Hexagon kknob for adjusting the low beam. You need a hexagon ended spanner to adjust it. But for the high beam it is not automatic as the other guy says. It just doesnt move at all and mine is pointing way too low. lower than the low beam even.
Old Sep 23, 2014 | 11:22 AM
pamiboy's Avatar
E 350
Thanks a lot.
