W212 Facelift Headlight LED Yellowish
Hi I am having a W212 facelift version. However, recently i found out left side of my headlamp having 2 stripes of LED daylight, one of it on the outer is yellowish in color instead of the original whitish. Anyone encounter this before knowing what's wrong? Is there any bulb change needed for this?
Any advice is much appreciated.
Hi, I attached picture of the problematic side. The stripe on the outer part is yellowish instead of the original bright whitish. Headlamp on the driver's side is having no problem. If this picture isn't clear enough I will repost when I try to take it at night.
I'm wondering if those are CCFL tubes and not true LED? The issue seems to be similar to a failing fluorescent, LEDs tend to either work or not.
Not sure, just wondering.
Anyone figured out if it's the ballast issue or do I have to change the whole headlight assembly?
One of my headlamps hockey stick LED strip is turning yellow. And nope, no warranty on a 2014 car
Received 1,616 Likes
2014 E550-sold 😩
Not liking this. Let us know if you take it to the dealer to sort it out. I’m sure the whole light needs replacing. I have these on the full LED, but just extended my CPO for another 2 years on a ‘14. I don’t want this problem
Posted last year and I got turned down for a replacement. Hope this helps other owners out there. Ok so, I have two 2014 W212's. Same issue with both cars. Long story short, the dealership replaced the entire headlight units for both cars.
First car: Auto highbeam function wasn't working on the driver side so they replaced the driver headlight. The new one was noticeably whiter than the passenger side. They replaced the other one.
Second car: Took the car to the dealer on a rainy day and asked them to compare the headlights to a newer 2016 model. They saw a difference and just replaced both.
