Sponsored by: CARiD
2010 E350 Service A
Old Sep 23, 2014 | 10:00 PM
mikesharma's Avatar
MB E350 4matic 2010
2010 E350 Service A
Hey Guys, Please tell me that how much the service A Cost on 50 K miles. Its 2010 MB E350 4matic . My dealer Charged me 1500 Dollars.
Old Sep 23, 2014 | 10:01 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
a plain service A should be about $200
Old Sep 23, 2014 | 10:08 PM
mikesharma's Avatar
MB E350 4matic 2010
What the plain services means.? when i called to my dealer that time he said its only 280 $.... but after service he gave me invoice of 1500 $ and told me that he did the transmission oil change and break oil change.
Old Sep 23, 2014 | 10:09 PM
thenew3's Avatar
Plain as in just service A which is basically an oil change and a few visual checks.
Transmission oil should have been changed at the 40k service for a 2010 E350. Same thing with brake fluid. which is every 2 years or every B service.
Old Sep 23, 2014 | 10:12 PM
mikesharma's Avatar
MB E350 4matic 2010
i brought my car on exact 40k miles , may be the dealer did not did that service that time..... what you think that everytime every service will cost me like dis.?
Old Sep 23, 2014 | 10:15 PM
thenew3's Avatar
Not sure what you mean by everytime every service.
Plain A service range from $170 to $300 depending on dealer (from what I've seen)
Plain B service ranges from about $300 to $500 depending on dealer.
a brake flush is $100 to $200
transmission flush is $350 to $700
All these are just quotes I've gotten from MB dealers in the central and northern CA area.
A and B services alternate, so at 10k it's A, 20k B, 30k A, 40k B, 50k A etc. Brake fluid flush every 2 years, and transmission flush for the 2010 7g tronic is every 39k or 40k miles. 2012 and newer 7g tronic plus is every 70k miles.
Old Sep 23, 2014 | 10:17 PM
mikesharma's Avatar
MB E350 4matic 2010
Ok thanks for your help.
Old Sep 24, 2014 | 01:38 PM
OAG's Avatar
OAG
E350 LUX 4M P2 D+
Saw a post recently on a MB forum (can't remember where) that the break fluid flush is done by Sears for $39.95 (a periodic special).
Old Sep 27, 2014 | 10:14 AM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
too cheap!
I wouldn't do this on a 10 year old clunker, much less an M-B. I do use Sears for tires, rotations and alignments though.
BTW, it is brake, not break - unless they are broken.
Regardless, point is to ask before taking car in and tell them the mileage and what was done on last two services and when done. Verify what they will do and how much it will cost when you check the car in.
Too many people just drop off car and say it is here for service and then sign the work order giving dealership OK to do what they think it needs.
Rember also that services are every 12 monthns OR 10,000 miles, whichever comes first or gives dealership most profit.
Old Sep 27, 2014 | 10:38 AM
imaphaetonguy's Avatar
GLC300
What is it you are afraid of?
I had my E350 brake fluid flush done for the $39.95 everyday price at Sears. (then took my wife's Lincoln there too) They used name brand brake fluid, vacuum drained each caliper, and topped off the tank. Same method as the MB dealer or any ASE certified mechanic would do.
Sears Brake Fluid
There are only about a half a dozen OE brake manufacturers in the world - Ate, Girling, Bosch, etc. A brake fluid change is done pretty much the same way on all of them.
There is NOTHING special about our E class brakes compared to an Accord, Camry, or Taurus.
