Engine temp warning + fan not turning on...looking for some help
The weird thing is that it seemed the fan worked at least one time, I definitely heard it spin up once after I shut the engine off (which normal on this car apparently) but now it is not kicking on.
Could it be that the fan is just bad? Or what is it that controls the fan...which sensor and could that have been damaged when the car fell?
Thanks for any help.
Buddy of mine that works at a shop checked it out and says it's the fan. Said he checked fuses and voltage and everything looks good, so has to be the fan. There were two error codes stored but unrelated, cleared those.
He also said the fan has to be programmed in? Something about setting it at certain percentage points (10% -90%)? Does that sound right?
