Sponsored by: CARiD
Front tire clearance
Old Mar 15, 2015 | 11:26 PM
valleywine's Avatar
2011 E350 sport sedan
Is anybody running 255/40/19 tires on the front of their w212? I want to use symmetrical size tires for ease of rotating them, if possible. The wheels I want to use are Niche Targa 19x8.5 or 19x9.5 with offset options of 25, 34 or 42. My car is an E350 sport sedan, not lowered. I want a bulletproof setup with no issues, but also want as big a tire as I can go. Thanks.
Old Mar 16, 2015 | 07:45 AM
beshannon's Avatar
2014 E350 Sport
I wish you the best of luck.
Old Mar 16, 2015 | 11:58 PM
valleywine's Avatar
Why the sarcasm? Am I wishful thinking I can upsize the front tires?
I've heard of guys running 265/35/19 and even some 20" sizes. I'm pretty confident a 255/35/19 will work well. And if I could fit a 40 series tire, all the better.
Old Mar 17, 2015 | 07:06 AM
beshannon's Avatar
2014 E350 Sport
After having 19"s on my BMW they were anything but "bullet proof".
I have no idea what size you can run but I do not think that large wheels and thin tires will ever be "bullet proof".
Although this appears to be a wheels for sale forum, perhaps you should try the wheel and tire calculator in the actual wheels and tires forum.
https://mbworld.org/forums/tire_rim_calculator.php
Old Mar 17, 2015 | 08:56 AM
noka's Avatar
'24 Porsche Macan
It would be nice if the desired size wheel and tire were listed as compatible in the Owner's Manual but that's not the case. People can only give you opinions. Even if someone is already running the same setup, that's no guarantee it won't present problems, not to mention harsher ride, increased likelihood of pothole damage (depending on location) and possibly altered handling charactistics, not necessarily for the better. You might have to try it to see whether it meets your definition of "bulletproof".
Old Mar 17, 2015 | 09:22 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Tires
Forget all the opinions. Go to http://www.1010tires.com/Tools/Wheel-Offset-Calculator# and plug in the stock sizes and what you want to do and see what comes out. There is also a link on that page to a tire size calculator.
Remember higher offset above stock is going to have more potential for clearance issues and, while I have no experience to go on I don't know what the implications might be on suspension if a relatively low offset i.e. 28.
Old Mar 17, 2015 | 04:03 PM
threeMBs's Avatar
Only MBs - the best or nothing
Not possible. (Its a 27" diameter).
Old Mar 17, 2015 | 10:17 PM
valleywine's Avatar
So, tire-size-conversion.com has some cool tools. According to the conversion table a 265/35/19 would actually be a closer fit than the 255/40/19 assuming I could spare another approx. 3/4" in tire width. The sidewalls are only slightly smaller. The ET42 offset would poke the wheel out +6mm over the stock ET48 offset I believe. Question is, will the outside fender be too close for comfort?
Old Mar 18, 2015 | 07:28 AM
noka's Avatar
'24 Porsche Macan
My 2015 Owner's Manual lists the following tire/wheel combination for the front axle (FA) of the E63. No idea if the clearances are the same for your car.
FA: 255/35 ZR19 (96 Y) XL
FA: 9.0 J x 19 H2
Wheel offset: 1.46 in (37 mm)
Old Mar 18, 2015 | 09:29 AM
threeMBs's Avatar
265/35-19 will barely fit front with perfect offset and width (9-9.5") wheel. As per original post, 8.5" wide wheel can not be used as 265/35 can not be mounted on it, so if you'll use 9.5" wide wheel (with offset of et42 as per above post) you maybe be too close on the inside to rub suspension (also tire will be outside the fender line). (As a side note, I have 255/35-19 on 9.5" wide wheels front and rear, 4matic, et42 front and et35 rear, upfront it has maybe 2mm room on the inside and wheel/tire pokes outside fender line a bit).
Old Mar 18, 2015 | 04:55 PM
Trancebolt's Avatar
w212 E350 Bluetec & Mk7 GTI Sport
Lol, that was great. I didnt know there was a wheels forum?! I totally just bookmarked this and w204. Never lurked around other categories.
Old Mar 18, 2015 | 05:51 PM
valleywine's Avatar
Bulletproof meaning no rubbing and car behaves as stock
Old Mar 18, 2015 | 09:55 PM
valleywine's Avatar
Originally Posted by threeMBs
265/35-19 will barely fit front with perfect offset and width (9-9.5") wheel. As per original post, 8.5" wide wheel can not be used as 265/35 can not be mounted on it, so if you'll use 9.5" wide wheel (with offset of et42 as per above post) you maybe be too close on the inside to rub suspension (also tire will be outside the wheel line). (As a side note, I have 255/35-19 on 9.5" wide wheels front and rear, 4matic, et42 front and et35 rear, it has maybe 2mm room on the inside and wheel/tire pole outside wheel line a bit).
By wheel line, you are referring to the outside lip of the wheel? So the tires would appear a bit beefy?
Old Mar 19, 2015 | 09:30 AM
threeMBs's Avatar
No, I meant to say "outside fender line" instead of "wheel line".
Old Mar 19, 2015 | 09:47 AM
noka's Avatar
'24 Porsche Macan
IMO, the only way to guarantee that would be to use factory-specified wheels and tires, and to at least be close, probably using the specified sizes of wheels and tires.
Old Apr 7, 2015 | 10:38 PM
valleywine's Avatar
threeMBs...........what tires are you using? I know some tires "run small" and I wonder if a guy could get away with the upsize? The E63, as I understand it (PER NOKA), runs the 255/35/19. Don't know the offset they use. Does anyone know if the E63 has the same dimensions as the e350, with regard to the wheels/tires clearances?
This is the difference in inches between the stock 245/40/18 and the upsize 265/35/19 tires according to tire-size-conversion.com
Diameter --> 25.7 / 26.3
Width --> 9.65 / 10.43
Sidewall --> 3.86 / 3.65
