Sponsored by: CARiD
2010 E350 Command Display turns GREEN
Old Apr 26, 2015 | 04:45 AM
saintaugustine's Avatar
E350
The command display flickered to the color green and now it has completely change to green. When the back up camera is engaged the screen is fuzzy and unclear. I have searched this sites, Googled, and YouTube and cannot find anyone with the same problem. I hope is not the display going bad.
Old Apr 26, 2015 | 02:52 PM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
A "green screen" usually means the display is not getting any video information. Could be the Comand electronics are bad or as simple as a bad connection. In any case this is not good.
Old Apr 26, 2015 | 09:38 PM
E350
thanks Carolina Bluetec. I had a Mercedes tech look at it and I was there when her ran the diagnostic test to the display. no indicators of a bad display from what he could determine. he recommended to replace the cable that connects the display unit. he recommended we start there.
Am I on the right track?
As I mentioned I cannot find anyone out there with the same problem. I can't believe I am the only one with this problem.
Old Apr 27, 2015 | 03:52 AM
Sgooter's Avatar
'14 E350, '03 H-D FXDL
Originally Posted by saintaugustine
thanks Carolina Bluetec. I had a Mercedes tech look at it and I was there when her ran the diagnostic test to the display. no indicators of a bad display from what he could determine. he recommended to replace the cable that connects the display unit. he recommended we start there...
Is your car under a warranty that covers this problem, including replacement of the display system, if needed?
Old Apr 27, 2015 | 08:08 AM
JSch's Avatar
2019 Mercedes-Benz GLS
I agree with replacing the cable. You have lost the yellow primary color of the display. If for the rest everything looks good, I would guess it is a bad cable or connection.
Old Apr 27, 2015 | 06:15 PM
E350
Unfortunately my 2010 E350 is over 4 years old and has 56,000 miles on her...I don't believe is under warranty. I'll have my technician change out the cable. I told me the cable is like a $60 and I am assuming 2 to 3 hours of labor. Hopefully that will fix everything.
I'll post again once I get it out of the shop.
Thank you all.
Old May 31, 2015 | 04:14 AM
E350
had the cable replaced
Took it in to replace the cable that connects the command unit to the display. unfortunately the green screen remains. the tech is not sure if the display needs to be replaced or the command unit. both parts are expensive now I am not sure which way to go.
Old May 31, 2015 | 08:21 AM
sghokie's Avatar
2010 e350
I wonder if you can source the parts from ebay or a junk yard.
