Sponsored by: CARiD
Command update
Old May 21, 2015 | 07:51 PM
Nikolica012's Avatar
2010 E350 4MATIC
Command update
I am trying to find an info about newest Command update for 2010 E350. I'm wondering does it work for iPhone 6, and does it enable Bluetooth audio streaming.
I found a thread from about month ago saying that it does work, but I can't get in touch with this person and my dealer is saying that it's not backward compatible and will not work.
Any help is appreciated.
Old May 21, 2015 | 09:42 PM
DJ Hellfire's Avatar
2013 E350 Sport
Works on my 2013. Isn't it the same system?
Old May 21, 2015 | 10:32 PM
Yeezus's Avatar
E350
Hey if you're trying to get Bluetooth audio you can do it by getting the command to enter engineering mode and activate through the menu.
I'm on mobile so can't link you to the thread but it's under the e350 hacks thread. Got it to work great with my iPhone 6.
Old May 21, 2015 | 11:24 PM
OnlyGerman's Avatar
Too many german broads
Enable through engineering menu, then go to the dealer stating you are having issues with the bluetooth audio cutting in and out and that you are also having issues with your phone when connected through bluetooth. Request they update the command software,( your cost) then you will have bluetooth audio listing as an option under "Audio" (like MY2011) and later.
Some dealers will tell you it is not possible but clearly it is, many have had success.
https://mbworld.org/forums/e-class-w...er-issues.html
Old May 21, 2015 | 11:45 PM
2010 E350 4MATIC
Yeah that should be the exact system like 2013.
I did enable it through engineering menu and after I restarted the system it showed up under audio.
However, I could get it paired only either as a Bluetooth audio or Bluetooth phone, but never both at the same time. Like there was some kind of conflict.
Maybe I didn't do something right???
Old May 22, 2015 | 01:04 PM
tiyyara's Avatar
W212 E350 4 Matic 2011
the latest NAV map update also updates the command software.
You can get it on ebay or from MB website for 250
It takes about 3 hours, plug and play
Old May 22, 2015 | 01:13 PM
belarus27's Avatar
2010 e550 p2
map update also updates the command software?????
if so I need that new maps cd lol
Old May 22, 2015 | 01:59 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I don't think the map update affects anything other than maps and POI's under NAV and the song title database for CDs.
There is another thread on here where a MB tech updated his comand to the last firmware using his system at work. Not sure if he gave all the details, but you should search for that thread as it may provide details you could refer to when getting your dealer to do it. Of course, updating comand 4.0 doesn't mean you get the features of comand 4.5, but those who got the update do say it helped their BT connection.
