Hard start after getting gas/now runs horribly
You are out of warranty paying your own.
The first step is to check the fuel rail pressure. You or your Indy shop can do this very easily. A fuel pressure gauge will cost you $20-$30 or so. I don't know the MB fuel pressure "standard" for these cars but I would think it is somewhere around 30-35 psi.The Stiger probably could tell us about the fuel pressure?
Fuel rail pressure check is an easy DIY job to do. Just need to know what the fuel rail pressure needs to be at.
If it is low it can be due to bad fuel pump or due to bad fuel pressure regulator, which should be located at the end of the fuel rail. Replacing this regulator should be an easy DIY job too.
Being a MB car does not mean it works any different than any other 4-stroke engine. MB has a way to build the cars so that people are afraid working on them but in the end of it the cars are actually build for the easiest maintenance. You just need to find out how to take the car apart.
