AZN Optics Aftermarket Lighting
SPONSOR/MBworld Guru
As most of you know, we're here to provide any assistance you might need in upgrading your Mercedes with the latest in aftermarket lighting from LEDs to HIDs. All of our products can be found and purchased on our website www.aznoptics.com! Our units are CANBUS compatible so error free! Plug and Play solution
AZN Optics are official distributors for Morimoto HID components. We've just upgraded our HID line with new XB35 HID conversion kits ($150/kit):
Already have OEM Xenons? We have replacement Morimoto D1S and D2S bulbs as well so you can upgrade to pure white 5000K and sportier white with a slight bluish hue 6000K.
We also have 194 wedge LED bulbs ($19/set) featuring our latest V5 technology paired with COB diodes and constant current IC drives to help protect and extend the life of the unit:
Festoon LEDs ($20/set) can also be had in a range of sizes (31mm, 36mm, 38mm, 39mm, 41mm) also uses our constant current IC drive:
Not sure what you need? No problem. Just shoot us a PM or email us at aznoptics@gmail.com and we'll be more than happy to assist you. Forum special bulk package discounts can be had as well!
Side mirror puddle lights use our 194 wedge LEDs
http://www.aznoptics.com/index.php?m...products_id=95
Additionally, here's a recent post with pics by another member with a w164 using our new V5 194 wedge:
https://mbworld.org/forums/m-class-w...ml#post6577329
Received 1,489 Likes
can you confirm I ordered the right lights.
1 x H11 Plasma LED Kit 5000K
1 x Morimoto XB35 Elite HID System - H7 6000K
2010 E350 SPORT with P1 Package...
H7 looks great but the H11 were the wrong bulbs. I wanted the drl replaced not fogs, plus they flicker and doesn't work correctly. I need to return them. Do you carry drl SH23w led? More research shows that these are the Drl. Do I have to pay for return shipping? I hope the installer didn't throw everything away.
Oh, you didn't specify you were looking for parking lights. When you listed the H11, I thought you were looking for fogs which should be H11 to go with the low beams you ordered. They shouldn't flicker though as we've had others install them before. You spliced in the load resistors right? and not just plugged in the bulbs? If you just plugged in the bulbs without the Morimoto load resistors then yeah, they will have issues like you described.
As for SH23W/P13W bulbs, we are currently in production on this base in our current production run and should have an initial run maybe end of this month.
And yes, we can process an exchange
Yes, and could you send us an email (aznoptics@gmail.com) with your username and current mailing address as part of our warranty/exchange process? We'll contact you when we get this unit in and shipped with tracking.
Hi Mike. I don't check in here often anymore, but I installed your kit on my E350 a couple years ago. Beautiful, looks great. Since you don't have W212 pics I'll take some with the DSLR next week and will post them up.
HERE ARE THE FOGS, RETURNING THEM FOR DAY TIME RUNNING, MY FOGS DIDN'T WORK WHILE DRIVING (I THINK I WAS MISSING RESISTORS), FOG LIGHTS ONLY WORKED WHILE PARKED. MICHAEL, I RETURNED IT FEW DAYS BACK, PLEASE TAKE A LOOK!
I WANT THE DAY TIME AND W5W LED PLZ! CALL ME FOR PAYMENT DIFFERENCE IF ANY...
What LEDs you recommend for the E class 2014 facelift (non lighting package) car's front indicator lamps. The bulbs in question are listed as PSY 24W. Do you have anything that is CANBUS error free for this bulb? Thanks.
Unfortunately we don't currently have PSY24W in stock. We'll probably make a few in our next production run though, probably by end of this month. There just isn't a high demand for that base.
